Author Topic: 1973 196 rebuild question  (Read 24699 times)
October 25, 2024, 07:10:32 PM
Reply #405
Re: 1973 196 rebuild question
« Reply #405 on: October 25, 2024, 07:10:32 PM »
Bulkhead tabbing process has begun.
4 innch layer of 1708 followed withe a 6 inch layer 1708. Plan is to do the other side tomorrow
October 28, 2024, 08:24:37 AM
Reply #406
« Reply #406 on: October 28, 2024, 08:24:37 AM »
Anchor locker/hatch question.  Any builds on here that are the go to for for hatch making. I am contemplating putting an anchor locker but cannot imagine the the hatch. See pic.
October 28, 2024, 08:29:31 AM
Reply #407
« Reply #407 on: October 28, 2024, 08:29:31 AM »
October 28, 2024, 08:30:16 AM
Reply #408
« Reply #408 on: October 28, 2024, 08:30:16 AM »
October 28, 2024, 08:32:30 AM
Reply #409
« Reply #409 on: October 28, 2024, 08:32:30 AM »
Any ideas or recommended builds to look at for weird shaped hatch making? Anchor locker hatch is a head scratcher. I have some ideas but suspect others may have better ones.
October 28, 2024, 04:57:26 PM
Reply #410
« Reply #410 on: October 28, 2024, 04:57:26 PM »
Added a thru stringer pipe for bilge pump hose to go thru and laminated casting deck supports
October 28, 2024, 08:52:10 PM
Reply #411
« Reply #411 on: October 28, 2024, 08:52:10 PM »
I will cut that pipe off
October 30, 2024, 04:06:51 PM
Reply #412
McAllgeyver
« Reply #412 on: October 30, 2024, 04:06:51 PM »
Scan My rebuild for anchor locker I made.
https://classicaquasport.com/smf/index.php?topic=14350.0
Not suite if link works.  :scrHead:
Sean A.
1973 19-6 Osprey - rebuilt
November 03, 2024, 05:12:29 PM
Reply #413
« Reply #413 on: November 03, 2024, 05:12:29 PM »
Rear knee is where the rear part of the deck meets the front portion of the deck so a wider area is preferable or at least that's the theory.
Here is a better picture of contemplated anchor locker. McAllister, thank you for the link. Very helpful.
November 03, 2024, 05:16:14 PM
Reply #414
« Reply #414 on: November 03, 2024, 05:16:14 PM »
Can I use Honey comb for the anchor locker bulkhead? It is so much cheaper.
November 04, 2024, 11:01:01 AM
Reply #415
dbiscayne
« Reply #415 on: November 04, 2024, 11:01:01 AM »
Sure can't imagine why not. Just keep in mind the need for future screws into it which the honeycomb won't work so good with. And beef up the laminate schedule if needed. 2 layers of 1708 ea side with 5/8" honeycomb makes a strong panel, the thicker the honeycomb the better.
November 05, 2024, 01:15:37 PM
Reply #416
« Reply #416 on: November 05, 2024, 01:15:37 PM »
Good info dbiscayne. Thanks. I'm using 3/4 hcomb for parts of my deck and will now use it for anchor locker too.  Thought I would cut out areas where hinges etc go and replace with Coosa before I laminate it. Or something like that.
November 05, 2024, 01:38:46 PM
Reply #417
McAllgeyver
« Reply #417 on: November 05, 2024, 01:38:46 PM »
I wouldn’t recommend honey comb for bulkheads that bear a significant amount of weight or structural tie in. However , up there under the front deck it should be fine.
Sean A.
November 05, 2024, 01:40:34 PM
Reply #418
McAllgeyver
« Reply #418 on: November 05, 2024, 01:40:34 PM »
design looks pretty cool. Great idea
Sean A.
November 05, 2024, 04:33:06 PM
Reply #419
« Reply #419 on: November 05, 2024, 04:33:06 PM »
Thanks for the input mcallgeyver. It will be structural for sure but in conjunction with a lot of other pieces that come together at that juncture. I'm going to give it a go.
