196 Rebuilds
1973 196 rebuild question
26
27
28
29
44
Topic: 1973 196 rebuild question (Read 24411 times)
September 30, 2024, 07:55:03 PM
Reply #390
Re: 1973 196 rebuild question
Reply #390 on:
September 30, 2024, 07:55:03 PM »
I was thinking 8 inch strip of 1708 on each side. Do you think that would do it and should I do 2 layers? Thanks for the input. It is much appreciated. Also here is the lamination of the h80. Very resin thirsty stuff. I hope I saturated it enough. That's the first time I've used it. Does anyone have any pointers for diving cell I need to know about.
September 30, 2024, 08:01:43 PM
Reply #391
Reply #391 on:
September 30, 2024, 08:01:43 PM »
Forgot, this is how I made the form.
September 30, 2024, 08:17:34 PM
Reply #392
Reply #392 on:
September 30, 2024, 08:17:34 PM »
Reinforcing the cap where you are going to be stepping to get onto the boat is always a plus - so adding new coring in those places. I add reinforcement where cleats are going to be. I used pop-ups so I used either about 6-8 layers of 1708 (makes about 3/8" thick glass) or I used composite (coosa) like you saw in the pics of the front of the cap. My front was bowed upward I guess for it to shed water, see if yours is. Will you be adding a trolling motor to the front of the boat? You'll want to add coring there for thru-bolting.
October 01, 2024, 08:37:07 AM
Reply #393
Reply #393 on:
October 01, 2024, 08:37:07 AM »
It definitely has a slight crown. I don't really like the small section at the bow. It looks like mounting a trolling motor would be space challenged. I am thinking anchor locker bulkhead with a slight crown, new bigger cap area for trolling motor. It's not even 8am, why am i thinking about this now, what the he'll is wrong with me?
October 01, 2024, 02:42:54 PM
Reply #394
Reply #394 on:
October 01, 2024, 02:42:54 PM »
You have the fiberglass bug - happens to all of us
Have you checked out removable mounting brackets like the RTA 17 for Minn Kotas? There are solutions for small areas.
October 01, 2024, 06:43:45 PM
Reply #395
Reply #395 on:
October 01, 2024, 06:43:45 PM »
Will leave the cap alone if I'm smart. Glassed the other side of the forward bulkhead and cut out the starboard rod holder hull st8ffener thing.
October 02, 2024, 08:48:31 PM
Reply #396
Reply #396 on:
October 02, 2024, 08:48:31 PM »
Front bulkhead glassed and another set of stiffeners cut out.
October 02, 2024, 08:50:19 PM
Reply #397
Reply #397 on:
October 02, 2024, 08:50:19 PM »
The starboard stiffener is cut low for the rigging tubes.
October 04, 2024, 10:23:19 AM
Reply #398
Reply #398 on:
October 04, 2024, 10:23:19 AM »
In the process of glassing the hull stiffeners. Putting a layer of 1708 and Matt on each side. Haven't decided whether I'm going to try to round and wrap the outward edge or something else
October 07, 2024, 07:46:57 PM
Reply #399
Reply #399 on:
October 07, 2024, 07:46:57 PM »
These knees take forever. Not hard to do but time consuming. The rear ones are two pieces of Coosa glassed together with 1708 and mat. The bow ones are made of divinycell with a layer of 1708 and mat.
October 21, 2024, 09:33:16 AM
Reply #400
Reply #400 on:
October 21, 2024, 09:33:16 AM »
Hopefully glassing the knees and deck rails (supports for deck to rest on) this week. Getting cool here but very doable. Temps are in the 70s and 40s.
October 22, 2024, 08:12:32 PM
Reply #401
Reply #401 on:
October 22, 2024, 08:12:32 PM »
5200ed the deck rails to the hull sides. Once those are cured will glass the knees in then the front bulkhead
October 23, 2024, 08:14:59 AM
Reply #402
Reply #402 on:
October 23, 2024, 08:14:59 AM »
5200 takes 48 to 96 hours to cure. I was unaware it took so long.
October 23, 2024, 08:35:12 PM
Reply #403
Reply #403 on:
October 23, 2024, 08:35:12 PM »
Started to glass the deck rail and glassed the deck support to the front bulkhead
October 23, 2024, 08:41:45 PM
Reply #404
Reply #404 on:
October 23, 2024, 08:41:45 PM »
Bulkhead
Also, starting to co template the console.
26
27
28
29
44
196 Rebuilds
