196 Rebuilds
1973 196 rebuild question
23
24
25
26
44
Topic: 1973 196 rebuild question (Read 24864 times)
August 30, 2024, 06:56:00 PM
Reply #345
Re: 1973 196 rebuild question
Reply #345 on:
August 30, 2024, 06:56:00 PM »
Roger on the lid. Looked like the lid made it easier to deal with rigging. I will kick that can. Laminated the stringer "risers" together. No pics. Not much to see. Looks like the other pic a few back but with a layer of mat you can't see.
August 31, 2024, 05:19:08 PM
Reply #346
Reply #346 on:
August 31, 2024, 05:19:08 PM »
Working on a "side stringer" for the deck to rest on. We'll see how it comes out.
August 31, 2024, 05:31:42 PM
Reply #347
Reply #347 on:
August 31, 2024, 05:31:42 PM »
Here is the stringer riser on the starboard side with the channels. I suppose I will glass on the underside of the channels. Do I need to put a layer of 1708 on the underside of the risers? I know it won't hurt but if unnecessary I have plenty of other work.
August 31, 2024, 05:47:19 PM
Reply #348
Reply #348 on:
August 31, 2024, 05:47:19 PM »
Put a steel fence post on the riser pieces to weigh it down for proper bonding of 2 pieces of Coosa with mat in between
August 31, 2024, 05:53:20 PM
Reply #349
Reply #349 on:
August 31, 2024, 05:53:20 PM »
On the side stringer, will need to match the curve of the hull and make sure it's the right height. I am going to look at Ricky's build gallery. Can anyone suggest other photo galleries or member builds?
September 01, 2024, 08:53:06 PM
Reply #350
Reply #350 on:
September 01, 2024, 08:53:06 PM »
This not the way to do it. I created a lot of grinding work. 1708 will not go around a corner if it doesn't have a long tail. In the rigging channels it did not have a long tail.
September 01, 2024, 08:58:52 PM
Reply #351
Reply #351 on:
September 01, 2024, 08:58:52 PM »
Will tab around all the joints including underneath. . Upside down glassing is always a crapshoot for me.
September 02, 2024, 10:48:46 AM
Reply #352
Reply #352 on:
September 02, 2024, 10:48:46 AM »
September 02, 2024, 10:52:27 AM
Reply #353
Reply #353 on:
September 02, 2024, 10:52:27 AM »
Forgot to post this pic of the side stringer/deck support. Probably should have done a 75° angle instead of 90°. Going to make it work. Haven't been able to find any pics or info on how everyone tabbed deck to hull side? Suggestions on how or member galleries to look at would be appreciated.
September 02, 2024, 02:47:16 PM
Reply #354
Reply #354 on:
September 02, 2024, 02:47:16 PM »
I didn't put a side stringer in. I glassed the floor right to the hull side because I was going to drop the liner back in and cover it all up.
September 02, 2024, 07:52:14 PM
Reply #355
Reply #355 on:
September 02, 2024, 07:52:14 PM »
More progress. Tabbed trough in and glassed some more of the starboard stringer riser. Starting to look righr
September 02, 2024, 07:54:17 PM
Reply #356
Reply #356 on:
September 02, 2024, 07:54:17 PM »
September 02, 2024, 07:58:19 PM
Reply #357
Reply #357 on:
September 02, 2024, 07:58:19 PM »
Rick, that is good news about the side stringer. I will not be putting the liner back in. Does it matter in terms of the side stringers in your opinion?
September 02, 2024, 08:31:55 PM
Reply #358
Reply #358 on:
September 02, 2024, 08:31:55 PM »
I think the side stringer probably adds rigidity to the hull since originally it was part of the stringer system that was set into the hull and also supports the deck.
September 03, 2024, 07:58:44 PM
Reply #359
Reply #359 on:
September 03, 2024, 07:58:44 PM »
Peanut buttered the port stringer down, glassed the remainder of starboard down.
23
24
25
26
44
196 Rebuilds
