196 Rebuilds
1973 196 rebuild question
41
42
43
44
Topic: 1973 196 rebuild question (Read 25249 times)
March 28, 2025, 06:24:40 PM
Reply #615
Re: 1973 196 rebuild question
Reply #615 on:
March 28, 2025, 06:24:40 PM »
Glassed other side, same schedule.
March 30, 2025, 11:15:50 PM
Reply #616
Reply #616 on:
March 30, 2025, 11:15:50 PM »
Looks good Duffy! Are you going to use honeycomb board as the coring material? I am curious how your experience is with it as I don't have much experience with it, YET. Curious to hear your experience and thoughts. Thanks for sharing!!
74'-240 -
https://classicaquasport.com/smf/index.php?topic=15975.0
68'- 222 -
https://classicaquasport.com/smf/index.php?topic=16422.0
70’- 222-
https://classicaquasport.com/smf/index.php?topic=15666.0
81’-222 -
https://classicaquasport.com/smf/index.php?topic=15249.0
72'-240 - SOLD
71'-222 - SOLD
March 31, 2025, 08:53:14 AM
Reply #617
Reply #617 on:
March 31, 2025, 08:53:14 AM »
U, the honey comb is light, inexpensive, and glasses into super stiff, zero deflection panels. Finishing the edges of this stuff is not something I have experience with, looks like a pain in the rear. Rick did a great looking, well documented job on his build, so it can be done. My strategy has been to terminate the ends in a major glass area, like deck to hull where no one will see the edges.
March 31, 2025, 11:59:17 AM
Reply #618
Reply #618 on:
March 31, 2025, 11:59:17 AM »
I should have been more clear...I have 9- 4x8 - 1'' Panels of Honeycomb (scrimmed backing, no glass) that I will use for decking materials. I glassed up one large panel of it so far and glassed it into the hull for a fuel tank subfloor in my 240 project. I am curious how your experience will be using it in a mold application. I would like to use it that way to build hatches, hatch gutters etc. in a
melamine mold. Not sure how to do it other than laying up the panels first with at least one layer of 1708 and sanding them down before setting them into the mold with some kind of thickened resin, putty compound, or 1.5oz chop strand mat.
74'-240 -
68'- 222 -
70’- 222-
81’-222 -
72'-240 - SOLD
71'-222 - SOLD
March 31, 2025, 06:34:21 PM
Reply #619
Reply #619 on:
March 31, 2025, 06:34:21 PM »
I already laid the deck down on the melamine. I trimmed it up today and will be glassing/bonding the honeycomb to it this week. I plan on putting a layer of 1708 or 2 over that. I can't answer your question yet but it should be soon.
April 02, 2025, 07:00:35 AM
Reply #620
Reply #620 on:
April 02, 2025, 07:00:35 AM »
U, I lied about coring with honeycomb. I forgot about this piece from a few weeks back. The comb cores great. The pics are of the shelf I added inside the console anD the comb will receive the end of an umbrella. My skills are limited, however this piece came out great so the product, comb, is easy to work with. Used a combo of matte and 1708.
Yes, the shelf is actually the front small hatch off the casting deck
Other work on coring the front deck
Layer of matte, then add comb
Weighted down
Also fixed vent hole in port hull side. Put packing tape on aluminum..... see pics
April 02, 2025, 07:03:39 PM
Reply #621
Reply #621 on:
April 02, 2025, 07:03:39 PM »
Other side of hole patch
Glassed underside of front deck. Will start fitting it tomorrow.
April 03, 2025, 11:41:57 AM
Reply #622
Reply #622 on:
April 03, 2025, 11:41:57 AM »
Deck came out good I think. Need to clean it up. Rick planted the deck rail idea in my head so I will do that next.
April 03, 2025, 04:56:21 PM
Reply #623
Reply #623 on:
April 03, 2025, 04:56:21 PM »
You don't have to have a rail if it fits tight and you can cover the glass work to the hull. That was what I was thinking when I mentioned the rail. You can glue the deck to the rail and fill the gap along the edge with thickened resin putty. If you have the liner to cover the joint, no problem.
April 03, 2025, 09:21:50 PM
Reply #624
Reply #624 on:
April 03, 2025, 09:21:50 PM »
I put some hard points in for the deck to rest on. Three on each side. I think you were right to suggest them. I am starting to lose my zeal for the project, so any time you see me cutting corners, please call me out.
April 04, 2025, 08:32:07 AM
Reply #625
Reply #625 on:
April 04, 2025, 08:32:07 AM »
U, finished the deck with the comb as core. Do you have any questions? I am more than happy to answer anything you have.
April 04, 2025, 09:58:50 AM
Reply #626
McAllgeyver
Reply #626 on:
April 04, 2025, 09:58:50 AM »
Looking great. That deck came out nice. If you can reach under deck and get some glass connecting hill and underside of deck it would be beneficial. That bow takes some beating. Glad you enlargerd the gutters which gives the hatch room to be thicker and stronger.
You’re in it now. Don’t lose steam. Classic Aquasport will get you to the end. And then some. Would unequivocally have not finished my boat if it was not for the few main guys here on CA. I owe them more than they know and will be forever indebted to them and CA.
Sean A.
1975 Banana River Skiff - rebuilt - SOLD
1973 19-6 Osprey - rebuilt
April 04, 2025, 04:07:25 PM
Reply #627
Reply #627 on:
April 04, 2025, 04:07:25 PM »
Roger that mcall on all points. I'm going to finish, but definitely plan on cheating at the end by having someone else paint it. If it looks like a 52 year old boat and my wife bitches it can be someone else's fault.
I don't know how I could glass from the underside. I am open to suggestions. Was planning on lots of gorilla glue construction adhesive ultimate. I could easily be talked into 5200. I have to order it online which is why I end up using the gorilla glue product.
I am definitely scared/reluctant/dreadful to glue and glass the deck down. That's it. Game over. If it's not in there, too bad. So, I will do as many other topside items first.
April 06, 2025, 02:27:26 AM
Reply #628
Reply #628 on:
April 06, 2025, 02:27:26 AM »
Duffy, project is looking good and coming along nicely. I was just curious about the laminate schedule for bedding the core. Did you laminate the side you bedded in the mold?
Do you have access to those three hard spots underneath the front deck or are those areas outside of the fish box and basically dead space? A good practice it seems common is to tie everything together with structural tabbing glass so its basically all one part. I believe the hull to deck joints should be glassed in.. in lieu of just 5200 or thickened resin. I know you spent all this effort on a smooth casting deck so I would get some Peel Ply and lay that on the structural ties so fairing isn't so bad.
74'-240 -
68'- 222 -
70’- 222-
81’-222 -
72'-240 - SOLD
71'-222 - SOLD
April 06, 2025, 02:51:28 PM
Reply #629
Reply #629 on:
April 06, 2025, 02:51:28 PM »
The laminate schedule from top to bottom is:
-matte
-1708 (matte side to above matte side)
-matte
-honeycomb
-Matte
-1708
I am definitely tabbing the deck in from the top but not the bottom (cant get to the dead space outside the fishbox/storage area to glass from bottom). The area of concern is the outside edge of the deck. The honeycomb is left exposed. If it were going to delaminate, I suspect it would be here. The bottom is supported by the hard points and will be glued and the top will be tabbed with two layers 1708 and layer of matte. I think it will be good.
41
42
43
44
196 Rebuilds
