Author Topic: 1973 196 rebuild question  (Read 23728 times)
March 01, 2025, 10:52:09 PM
Reply #570
Re: 1973 196 rebuild question
« Reply #570 on: March 01, 2025, 10:52:09 PM »
Flipped cap over. It's a mess. Not sure what I'm going to find under the Grey paint.
March 01, 2025, 11:02:18 PM
Reply #571
« Reply #571 on: March 01, 2025, 11:02:18 PM »
Also been working on console. Hard to take pics of the inside of this thing. I will say this, there's no way to recore any part of the console without taking it out of the boat. I will try to take some pics
March 02, 2025, 05:14:40 PM
Reply #572
« Reply #572 on: March 02, 2025, 05:14:40 PM »
Console innards. Cored the top of console with Coosa. Its 1/4 inch plus. Not really sure. Other pics speak for themselves
Cap work. How rough is too rough. Trying to figure out if it is possibly "totaled"
March 03, 2025, 06:53:53 PM
Reply #573
« Reply #573 on: March 03, 2025, 06:53:53 PM »
Well, I can't say I'm proud of myself. I cut the front of the console off to make room for a cooler. What the hell am I doing? Much of boat rebuilding has been like that. Somehow it's fun?
March 04, 2025, 09:16:08 AM
Reply #574
dbiscayne
« Reply #574 on: March 04, 2025, 09:16:08 AM »
are you gonna put some kind of shelf inside, above the cooler, and maybe a wall to separate that cooler space from the rest of the inner console? Seems like if you don't you'll get all kinds of spray on your wiring & everything else in there. But also consider being able to drain that new space you created,  I did something similar and it would always get pretty nasty in there cause I didn't provide a good way to get the water out.
March 05, 2025, 01:39:46 PM
Reply #575
« Reply #575 on: March 05, 2025, 01:39:46 PM »
My plan is to use the pieces I cut off in some fashion. See below
Probably not this one
Leaning towards this one
The geometry on the cut off pieces is the same so why not take advantage of that and not recreate the wheel. The cooler is going to be a yeti 45 or 65 that sits in front of the console. Again, why recreate the wheel. In the next picture use your imagination in regards to altering the existing hatch to fit.
March 05, 2025, 02:14:22 PM
Reply #576
« Reply #576 on: March 05, 2025, 02:14:22 PM »
What does it mean that my post is brown and has a pin in it?
March 06, 2025, 05:24:14 AM
Reply #577
« Reply #577 on: March 06, 2025, 05:24:14 AM »
Not sure I understand the question...
March 06, 2025, 08:14:52 AM
Reply #578
« Reply #578 on: March 06, 2025, 08:14:52 AM »
I should have included this with my question. My apologies. The thread, or whatever it's called, is brown. It did not used to be like this. I don't really care one way or another, just curious.
March 06, 2025, 09:08:39 AM
Reply #579
dbiscayne
« Reply #579 on: March 06, 2025, 09:08:39 AM »
Console makes sense now - I thought you were going to have an opening into the front to put the cooler in the console. For the upper opening, you don't have any of those tackle storage shelves laying around do you?
March 06, 2025, 02:18:48 PM
Reply #580
« Reply #580 on: March 06, 2025, 02:18:48 PM »
The pictures are key. Language does a poor describing most of boat rebuilding.  As far as a tackle shelf, are you referring to the shelf I ripped out of the console that other aquas i am familiar with have in the console? If yes, I have an idea for that. I will follow up with pics but for now I will try to use my words. The piece I cut off that ended up being two pieces have a lip at the top (and a flange at the bottom for miunting to deck) that the seat/hatch sat on. I was contemplating gluing or glassing those inside the console to provide a rest or support for a shelf.
March 06, 2025, 02:46:03 PM
Reply #581
dbiscayne
« Reply #581 on: March 06, 2025, 02:46:03 PM »
something like this to fill part of the big hole in the upper half.
March 06, 2025, 03:46:43 PM
Reply #582
« Reply #582 on: March 06, 2025, 03:46:43 PM »
I think you made it a sticky topic and that changed the color. I "unstuck" it.
March 07, 2025, 11:03:09 AM
Reply #583
« Reply #583 on: March 07, 2025, 11:03:09 AM »
Was talking about adding a lip on the inside of console. Below are pics illustrating the idea
Cut off at transition to flange (haven't done that in any of the pics yet)
March 07, 2025, 11:15:02 AM
Reply #584
« Reply #584 on: March 07, 2025, 11:15:02 AM »
Not necessarily related to above pics but what I am doing to redo the console. Have to glass it all together now
