Author Topic: 1973 196 rebuild question  (Read 22929 times)
December 07, 2024, 04:12:57 PM
Reply #465
Re: 1973 196 rebuild question
« Reply #465 on: December 07, 2024, 04:12:57 PM »
Also glassed 2 layers 1708 and layer of Matt on starboard deck section.
December 11, 2024, 06:29:33 PM
Reply #466
« Reply #466 on: December 11, 2024, 06:29:33 PM »
2 layers 1708 9n other side of deck piece. Will get pics after it cures
December 15, 2024, 10:27:36 PM
Reply #467
« Reply #467 on: December 15, 2024, 10:27:36 PM »
Dragging my feet on glassing in rigging tubes. They are about where I want them. Pushed some test cables through them. All good for that..
December 17, 2024, 02:57:01 PM
Reply #468
« Reply #468 on: December 17, 2024, 02:57:01 PM »
Really ugly glass job but hopefully I will never see it again.  Rigging tunes installed for better or worse.
December 18, 2024, 11:45:01 AM
Reply #469
« Reply #469 on: December 18, 2024, 11:45:01 AM »
So, how many drain holes in each rigging tube does the community recommend? They obviously need to be in the lowest spot, but after that I am at loss for the number of holes. Right now I have 2 holes In each tube at the 45 degree tu=n.
December 18, 2024, 11:51:53 AM
Reply #470
dbiscayne
« Reply #470 on: December 18, 2024, 11:51:53 AM »
I poured 2lb foam under my deck between the stringers except against the transom where the tubes were. Added about a 1/4" hole at the very back/rear end of the tubes just before they bend up, this was the only area not foamed under the deck where my tubes ran. Have a 1" drain at the bottom of the stringer against the transom connecting the cavity to the bilge. Just made sure I sealed the rigging tubes real good where the wiring exited so hopefully I don't get any water in there.
December 18, 2024, 06:52:39 PM
Reply #471
« Reply #471 on: December 18, 2024, 06:52:39 PM »
Roger that. Perhaps I will just seal them extra good.
December 20, 2024, 07:14:12 PM
Reply #472
« Reply #472 on: December 20, 2024, 07:14:12 PM »
Glassing the center section of the deck. layer of 1708 and layer of mat on the top.. Should I do 2 layers of 1708 I n bottom?
December 21, 2024, 06:18:30 AM
Reply #473
« Reply #473 on: December 21, 2024, 06:18:30 AM »
2 layers on the bottom will stiffen up the whole thing
December 21, 2024, 01:24:21 PM
Reply #474
« Reply #474 on: December 21, 2024, 01:24:21 PM »
Gracias mi amigo. I will do that
December 21, 2024, 04:03:14 PM
Reply #475
« Reply #475 on: December 21, 2024, 04:03:14 PM »
Glassed layer of 1708 then started running low on resin and could only get one additional 25 inch wide strip down the middle. I suspect that will work, but we will see.
December 24, 2024, 04:18:44 PM
Reply #476
« Reply #476 on: December 24, 2024, 04:18:44 PM »
Anchor locker and rigging tube snorkel pics.
 The rigging tube snorkel is just an idea but it would work well to keep water and other random items out of the bilge. Your thoughts would be appreciated.  Merry Christmas  everyone.
December 28, 2024, 09:56:48 PM
Reply #477
« Reply #477 on: December 28, 2024, 09:56:48 PM »
Finally glassed the anchor locker in.
December 30, 2024, 11:36:02 AM
Reply #478
« Reply #478 on: December 30, 2024, 11:36:02 AM »
Looks good :clap01:
December 30, 2024, 08:35:59 PM
Reply #479
« Reply #479 on: December 30, 2024, 08:35:59 PM »
Forward storage floor cut and glassed some on the cap to fix the holes from I m the rod holders. Forward storage should hold two 5 gallon buckets and a 45 qt yeti cooler. Used two circles of mat, a layer of 1708 and a layer of 4008 (super heavy) on rod holders.
