196 Rebuilds
1973 196 rebuild question
8
9
10
11
26
Topic: 1973 196 rebuild question (Read 8246 times)
June 25, 2024, 09:37:48 AM
Reply #120
Re: 1973 196 rebuild question
Reply #120 on:
June 25, 2024, 09:37:48 AM »
What you see in the pic is a 25 inch wide by 40 in long piece of 1708 laid 12 inches on the hull and 12 8nches on the transom and 4 inches up the gunnel. Did this on both sides of hull. The two pieces overlap in the center on the transom above the drain. Then another piece on both hull sides fr9m bottom to top. A lot of the builders on this site are just better at laying glass than me, really talented builders. About the most I can manage at a time is the 40 x 25 piece 9f 1708 and that was wit help from my s9n, who also has never worked with glass. At the end of the day, though it's satisfying to see your work, whether it's perfect or not.
Thanks all for your help everyone.
June 25, 2024, 12:27:26 PM
Reply #121
Reply #121 on:
June 25, 2024, 12:27:26 PM »
Clamp a 1x2 across the aft of the hull sides and use it to hang the cloth on and down into the boat. If you are going to lam 2 layers, clamp 2 layer onto the 1x2. Then you let is hang into the boat where you can trim it and cut pleats for the corners. When you have both layer trimmed, flip them out of the boat. Then mix resin and roll it on the core and flip the first layer back into the boat. Roll and resin roll everything flat, bubble free and tucked into the corners. Wet the first layer down again and flip the 2nd layer in and repeat.
Link to where I did this in the rebuild
https://classicaquasport.com/smf/index.php?topic=10101.msg89625#msg89625
June 25, 2024, 04:12:25 PM
Reply #122
Reply #122 on:
June 25, 2024, 04:12:25 PM »
I tried to do that and screwed it up. I couldn't get my head around that I am not enclosing the transom and cut the pieces to size and tried to clamp them to the transom instead of a board across the top which obviously failed. I was also using that 40 Oz crap, blah blah blah..... listen to what the people here are doing and copy them precisely. I will give the "hanging gardens" technique another try. Thanks.
June 25, 2024, 05:08:45 PM
Reply #123
Reply #123 on:
June 25, 2024, 05:08:45 PM »
Yes, you'll be cutting off some of the upper part of the cloth that is filling the cutout. You won't be wetting that part anyway.
June 26, 2024, 09:12:55 AM
Reply #124
Reply #124 on:
June 26, 2024, 09:12:55 AM »
Now my next problem. I can only get 25 inch wide rolls of 1708 locally here in middle TN and I don't want to spend the money anyway. 3 x 25 = 75..... I need to do these vertically across the back off the board onto the transom.
Question:
- in the corners where the glass bunches up
*do you cut a slit and overlap the pieces? Or
*do you cut a wedge and butt the edges instead of overlapping?
*does it matter?
I've done both and can't see that it matters. Looks a little stronger to overlap but it's a little harder to glass, likely bubble area. Have a great day everyone.
June 26, 2024, 03:04:00 PM
Reply #125
dbiscayne
Reply #125 on:
June 26, 2024, 03:04:00 PM »
The corners get tricky, you described it right. Happens on inside and outside corners but obviously no overlap on the outside corners.
Personally I overlap just about every time if it's not in an area that'll be exposed as part of the finished product. I do the trimming after most of the glass has been placed with resin to hold it so you end up cutting in the right spot.
Just keep a rag w acetone handy to clean the scissors I always end up w resin on them. Found it helps to cut just a little further up into the glass than I think I need.
June 26, 2024, 03:44:54 PM
Reply #126
Reply #126 on:
June 26, 2024, 03:44:54 PM »
Thank you dbiscayne. The overlap where no one else sees it makes sense. I will do that.
June 27, 2024, 05:19:47 PM
Reply #127
Reply #127 on:
June 27, 2024, 05:19:47 PM »
Cutting after it's we out, i just did that and it's brilliant. Thank dbiscayne
June 29, 2024, 07:54:56 AM
Reply #128
Reply #128 on:
June 29, 2024, 07:54:56 AM »
More progress. 3 layers of 1708. Plan is to copy Rickk and dbiscayne's builds. Once I get this dry fitted, will use thickened poly to glue it to the existing stringers. Then it is two layers of 1708 down each side, foam, two 3/4 inch planks of coosa glued together with a layer of csm on top to raise deck and finally 2 more layers of 1708 over the top
June 29, 2024, 08:21:39 AM
Reply #129
Reply #129 on:
June 29, 2024, 08:21:39 AM »
Duffy, you’re making some great progress! I have been watching along in the background. Nice work on laying up the stringer in the mold. I’ve learned that anywhere you can possible use mold techniques will save a good bit of work and makes for professional looking work as well. It also helps to save a ton of work on fairing and filling and getting a flat sanded finish. I learned the hard way trying to cold mold the top of my ‘81 console.
I have a comment on the double stacked coosa. Have you seen the fence post trick people use to raise the stringers? Seems much more cost effective because that 3/4” coosa isn’t cheap stuff. It’s great for transoms but not necessary anywhere else.
1974' 240 CC -
https://classicaquasport.com/smf/index.php?topic=15975.0
1970’ Flatback 222 -
https://classicaquasport.com/smf/index.php?topic=15666.0
1981’ Osprey 22-2 -
https://classicaquasport.com/smf/index.php?topic=15249.0
1971’ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
June 29, 2024, 11:29:44 AM
Reply #130
Reply #130 on:
June 29, 2024, 11:29:44 AM »
I did see the fence post method and can't find the post. The cost of coosa is a concern. Is there anything special i need to do for where the console and possible future t top mount to the deck. My initial plan is to take a 115 yamaha I have that is r8gged for a side console and do just that, rig a simple side console with all the rigging going under the cap. I suspect I will upgrade the motor and will want a center console at some point so I'm going to run all the tubes etc as I rebuild.
Have any of you seen or heard of anyone coring the hull sides with divine cell? I am not putting the liner back in and I thought that might be a good solution, remembering that I don't know anything.
Thanks for the kind words Ulysses. I forgot to mention copying your builds, also. Been extremely helpful to access yalls info and pics.
June 29, 2024, 03:49:52 PM
Reply #131
Reply #131 on:
June 29, 2024, 03:49:52 PM »
I d9nt know if the pic is good enough to see. I am having a difficult time getting the 1708 over the corner of the transom. How rounded does the corner need to be or should I use csm?
June 29, 2024, 04:00:24 PM
Reply #132
Reply #132 on:
June 29, 2024, 04:00:24 PM »
Also, my transom is 21 inches. Long story of stupidity how it got that way. It's not going to get shorter. Does everyone agree these are my options:
1. Cut an inch off the transom
2. Dont cut the transom and Get a jack plate, manual or otherwise to compensate for the engine being to high
Any input would be appreciated. Thanks
June 29, 2024, 08:50:36 PM
Reply #133
Reply #133 on:
June 29, 2024, 08:50:36 PM »
Maybe I missed it if you already have a motor with a 20” shaft but why not go with a 25” transom? Probably not something you want to hear at the stage you’re at but now would be the time to make the correction. 25” transom on this size and style of hull is fairly typical with the new range of horsepower available. However, a 20” will work just fine assuming it’s strictly inshore and backwater style fishing you’re looking to accomplish. To answer your question, I would not add ANY additional weight to a 20” transom by means of a jack plate and would correct the height now to 20” if you a already have a motor with a 20” shaft length. However, I would think strongly toward raising it to 25” vs 20”. Just my opinion. Either will work but it depends on your end goals.
1974' 240 CC -
1981’ Osprey 22-2 -
June 29, 2024, 10:00:55 PM
Reply #134
Reply #134 on:
June 29, 2024, 10:00:55 PM »
Thank you Ulysses. If I were to tack on 4 more inches, what would that process look like? Is it as simple as filling in the cutout with some Coosa and glassing?
8
9
10
11
26
196 Rebuilds
