Aquasport Discussion
215DC repower question 🙋♂️
Topic: 215DC repower question 🙋♂️ (Read 957 times)
April 09, 2024, 09:28:32 PM
Read 957 times
Aqualife
April 09, 2024, 09:28:32 PM »
Getting ready to repower my 1999 215DC. Pretty sure I’m going with a Suzuki 200. Current motor is a 1999 Johnson 200. Couple of questions below - all input is welcome.
- Often idle in and out of shallow waters. Any suggestions on a Jack plate? Brand, setback, etc?
- Looking to add trim tabs. Electric vs. hydraulic? What size?
Trey
1999 Aquasport 215 DC - Suzuki 200
2006 Mitzi Skiff 17’ - 60hp Etec
April 12, 2024, 08:10:17 AM
plugger
Re: 215DC repower question 🙋♂️
April 12, 2024, 08:10:17 AM »
I did that exact motor swap…. No idea about a Jack plate etc….
April 16, 2024, 08:26:32 PM
Aqualife
April 16, 2024, 08:26:32 PM »
Plugger - what’s your top speed and what prop are you running?
April 17, 2024, 08:10:48 AM
plugger
April 17, 2024, 08:10:48 AM »
Not a WOT guy but I’ve touched 40 mph and in a twenty footer that’s plenty
Have had a 3/16/20 and a 3/16/18.5 both Suzuki props not much difference.
April 17, 2024, 01:05:16 PM
Aqualife
April 17, 2024, 01:05:16 PM »
Thanks for the info!
June 15, 2024, 08:35:35 AM
Aqualife
June 15, 2024, 08:35:35 AM »
Update: installed a 2024 Suzuki 200A and a 6” Bobs Jackplate. I think it’s a perfect match. Top speed with a 21 pitch is 46 mph. Planes good without trim tabs but might be an add on in the future. Very happy I went with the Jackplate. Helps with the trim but also opens the motor well space for rod holders. Let me know if you have any questions.
June 15, 2024, 11:52:07 AM
June 15, 2024, 11:52:07 AM »
Looks good and should be a perfect match for your boat. Is the jackplate electric?
June 15, 2024, 01:03:09 PM
Aqualife
June 15, 2024, 01:03:09 PM »
Rick - it’s the self contained hydraulic version. I don’t have any experience with other Jackplates but IMO it’s quick and seems robust.
June 22, 2024, 07:59:53 PM
Scode68
June 22, 2024, 07:59:53 PM »
Looks great, I really like how it opens up the motor well.
2001 Osprey 215 Sport
August 18, 2024, 10:44:57 AM
d.suts
Reply #9 on:
August 18, 2024, 10:44:57 AM »
Trey,
Looking at a purchasing the same boat for my Son and possibly re powering it with the Zuke 200 also. Do you think it would of had enough engine well clearance without the Jack Plate when fully raised?
Also without the plate, do you think the entire engine of been out of the water when raised.
Are you happy with the power of the 200 on that boat?
I re powered my 225 Explorer 3 years ago with the Zuke 250 and love it. Thanks for your time!
Dave
August 18, 2024, 11:59:00 AM
Aqualife
Reply #10 on:
August 18, 2024, 11:59:00 AM »
Hi Dave,
I think you could tilt all the way without the Jackplate. However, even with the Jackplate, the foot is not out of the water. I’m very pleased with the 200!
Trey
August 18, 2024, 11:47:06 PM
d.suts
Reply #11 on:
August 18, 2024, 11:47:06 PM »
Thanks for the quick reply! My 225 Explorer does the same thing raised. About the same amount is always in the water. It was worse and found that there was an adjustment on the Engine that let me raise it up a little more that was preset most likely from the factory. Search YouTube “Suzuki Trim Limiter Switch”. I came upon that by accident. Just pay attention that you’re extra careful with not interfering with your steering ram and any control cables. If you not maxed out with the limiter you may get some more lift height to get it closer to being out of the water.
Jump to:
=> Aquasport Discussion
