Author Topic: 1976 Aquasport 19-6 Weight / Towing Advice  (Read 334 times)
April 09, 2024, 10:51:56 AM
Read 334 times
jtc99
« on: April 09, 2024, 10:51:56 AM »
A friend of a friend recently upgraded from a '76 19-6 and is looking to sell it. It seems like a pretty sweet deal: new transom professionally redone, 2007 Merc 115, new wiring, hoses, new cushions, fresh coat of varnish on the wood features, and some electronics, plus a trailer.  Luckily my buddy put me at the top of the list to take a look and make an offer if I would like.
My predicament is I may lack towing ability with my current car ('19 SUB Outback 3.6R).  My car is rated for 2,700lbs. After some Google-ing, it seems this published weight for the hull was 1,550lbs, that presumably doesn't include motor.  The 2007 Merc has a published weight of 375lbs.  In total we are looking at roughly 2,000lbs.
Does anyone have any insight on the weight of this hull and if I should tack on some additional pounds due to the age of the hull?  Shot in the dark: has anyone towed a similar hull without a legitimate towing vehicle (i.e., a truck)?
Long term I'd like to get a slip or a mooring, but the wait lists in my area are pretty long (5+ years). I've thought about a store + launch service at some of the local marinas, but they are very pricey and you have to work on their time schedules.
Thank you all for the input.
April 09, 2024, 01:49:07 PM
Re: 1976 Aquasport 19-6 Weight / Towing Advice
« Reply #1 on: April 09, 2024, 01:49:07 PM »
That hull/trailer combination would be over the capacity of that vehicle. Whether it will be successful at towing it down the road and whether it’s a safe option would be two different answers (legally and safely). Why not find a cheap ½ ton truck and use as your tow vehicle? Some of the weight that you might be forgetting are as follows:
Trailer – approximately 950lb
Fuel - 6lbs per gallon
Ice/drinks/live bait well – 8.4lb/gallon
1971’ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
