Author Topic: Shaft Length: Minn Kota 72”/112lb Trolling Motor  (Read 651 times)
January 24, 2024, 11:08:28 AM
Read 651 times
Capt.Joe
    • Speak Easy Fishing Charters
« on: January 24, 2024, 11:08:28 AM »
Hello,
I’m about to pickup a used trolling motor with a 72” shaft and was wondering if anyone had installation tips?
Is 72” long enough and where/how is the best way to mount it?
Thanks in advance!
February 06, 2024, 08:08:07 PM
McAllgeyver
Re: Shaft Length: Minn Kota 72”/112lb Trolling Motor
« Reply #1 on: February 06, 2024, 08:08:07 PM »
What boat is it for?
Sean A.
1973 19-6 Osprey - rebuilt
February 07, 2024, 05:10:10 AM
« Reply #2 on: February 07, 2024, 05:10:10 AM »
 This is his boat
February 07, 2024, 05:58:54 AM
« Reply #3 on: February 07, 2024, 05:58:54 AM »
Trolling motors more efficiently "pull" a boat than "push" one.  That being said, a 112lb TM is a 36V TM, 3 batteries.  Have you planned for that much weight and if they'll be forward, like inside the casting deck, remember you could also be in the front fishing - lots of weight forward. If planned out, it's not a bad thing but unplanned it can throw your center of gravity (COG) off. The '72 shaft was the longest they made until fairly recently but now they have more lengths, depending on the model of TM, up to 100". I think these newer lengths came about because bigger boats wanted a trolling motor too and the bow was higher in the air. For your 222 I think that the 72" should be fine. I see they also offer a 62" on their hand controlled models, which would be great for a 170/175. I'm using a RTA-17 removable mounting backet.
February 11, 2024, 06:13:33 PM
Capt.Joe
« Reply #4 on: February 11, 2024, 06:13:33 PM »
Thank you Rick!
I ended up getting the trolling motor for $500 and it works great.
Installed the motor at the nose of the bow and my batteries are under the center console to keep the center of gravity balanced. I’ll be testing it out this weekend.
February 11, 2024, 06:44:06 PM
« Reply #5 on: February 11, 2024, 06:44:06 PM »
 :thumleft:  Looks good
