Author Topic: 1997 175 soft deck  (Read 393 times)
September 25, 2023, 08:47:41 AM
Read 393 times
Jayson175osprey
1997 175 soft deck
« on: September 25, 2023, 08:47:41 AM »
Quick question for those with experience. I have to replace the ply under deck. Would you recommend pulling the cap or cutting the deck?
Jayson
September 26, 2023, 05:18:08 AM
  • Information Online
Re: 1997 175 soft deck
« Reply #1 on: September 26, 2023, 05:18:08 AM »
Is all the deck bad or just in a place or two?  There is alternatives.
September 26, 2023, 11:59:59 AM
Jayson175osprey
« Reply #2 on: September 26, 2023, 11:59:59 AM »
I’d say about 75% of the deck is soft. Especially under the seat and console. I can see wet foam in access ports as well.
Jayson
September 26, 2023, 05:58:23 PM
« Reply #3 on: September 26, 2023, 05:58:23 PM »
Here is a pic of a '87 170's stringers.
I don't think they redesigned the stringers much after they put the fuel tank below the sole. You can see that there are 2 stringers with a 30+ inch gap between them. More forward you should have a bulkhead fore and aft of the tank and this supports the sole in those areas.
What you may think is soft decks could be the unsupported areas of the deck between the stringers. There is usually an open area around the beginning of the casting deck also.  The fuel tank "lid" is also unsupported and is alway giving a spongy feeling.
