Author Topic: 2001 225 osprey  (Read 485 times)
September 21, 2023, 09:03:07 PM
Read 485 times
xavierhn
2001 225 osprey
« on: September 21, 2023, 09:03:07 PM »
Hello all. New member and new Aquasport owner. Thank you for accepting me. I recently bought this 2001 225 osprey. I’m making it mine one fuse at a time. The fuse box that’s located in the transom with the 40anp fuse along with the 3 panel mounted fuse labeled 2 bilge pumps and a stereo. I am wondering what size (amp) fuse they are? They are very corroded. In addition, most of my switches at the console are not working with the exception of the anchor/running lights and horn and bilge pump. I’ll be changing all the fuses out and run meter on it just to make sure it has juice.  Any pointes is appreciated.
July 30, 2024, 07:57:02 PM
Searoach
Re: 2001 225 osprey
« Reply #1 on: July 30, 2024, 07:57:02 PM »
I have the 2001 250 Osprey I know the switch you’re talking about chances are you do not have a front bilge so that would be empty. Your rear bilge and stereo fuses are self-explanatory put a lot of dielectric grease on all of your connections is my advice your stereo fuse Can be pulled so it does not drain your battery when not in use if it is not on a switch past this fuse
