Author Topic: Fuel filter - brown stuff in water separator bowl  (Read 192 times)
August 07, 2023, 01:29:49 PM
Read 192 times
rhtrades
« on: August 07, 2023, 01:29:49 PM »
Anyone ever see something similar to this browinish stuff in their fuel/water separator filter?  I haven't drained the bowl yet....is it most likely just dirty water and is it typical to see in today's ethanol blends?
August 07, 2023, 03:19:37 PM
dbiscayne
Re: Fuel filter - brown stuff in water separator bowl
« Reply #1 on: August 07, 2023, 03:19:37 PM »
ethanol fuel doesn't have that brown stuff in it. But if you've got an older boat that used to run old style gas without ethanol you'll get a varnish build up in the tank like a scum line where the fuel is filled to in the tank. Not a problem as long as you always use ethanol free fuel, problem arises when you put fuel with ethanol in the tank it ends up loosening up that varnish. Or so I've heard. You should have another filter under the cowling that should also be replaced.
August 07, 2023, 03:26:38 PM
rhtrades
« Reply #2 on: August 07, 2023, 03:26:38 PM »
Thanks for the helpful response.
