Paints, topsides and bottom and Gelcoat Topics
Hull Repair
Topic: Hull Repair (Read 962 times)
July 31, 2023, 01:58:24 PM
Read 962 times
umecheme
NorthEast
Hull Repair
July 31, 2023, 01:58:24 PM »
So I finished my hull repair, sanded down the keel area, filled and epoxied new glass over the section of the keel where the PO had been beaching. Now that the repair is finished, what's my best option? I'll sand it down and do a little bit of fairing, but should I gelcoat over the repair? I know I'm not supposed to use topside paint below the water line, but what if i'm going to be bottom painting over it? Thoughts? I'm reading up on it now, but haven't found a great answer.
Thanks, in advance!
-Mike
July 31, 2023, 01:59:43 PM
Re: Hull Repair
July 31, 2023, 01:59:43 PM »
Will it live on a trailer?
July 31, 2023, 02:10:53 PM
umecheme
NorthEast
Re: Hull Repair
July 31, 2023, 02:10:53 PM »
Its possible that it could end up on a mooring for a couple weeks a year....
July 31, 2023, 04:07:15 PM
wingnut
Re: Hull Repair
July 31, 2023, 04:07:15 PM »
Epoxy barrier coat (the gray stuff) followed by bottom paint would be a good option... I don't know that there's any reason to go down the cosmetic gelcoat route if you're going to bottom paint for aesthetics anyway. Barrier coat not a bad idea but might not even be necessary in your application. Glad to hear you're making progress!
July 31, 2023, 05:32:50 PM
Re: Hull Repair
July 31, 2023, 05:32:50 PM »
Here is what I did to my 170
https://classicaquasport.com/smf/index.php?topic=10101.msg129891#msg129891
August 10, 2023, 08:47:16 AM
msteinkampf
Re: Hull Repair
August 10, 2023, 08:47:16 AM »
Wingnut's suggestion sounds good. If you're going to be beaching the boat, I would install a KeelGuard (
https://keelguard.com/product/keel-guard/
). I've had one on my Boston Whaler Montauk 17 for a decade, and it's holding up pretty well. Lifetime warranty, too.
M
1990 Boston Whaler Montauk 17 with 2025 Yamaha F70LA outboard
1995 Aquasport Explorer 245 with twin 1995 Yamaha Salt Water Series 150 HP
August 23, 2023, 03:30:45 PM
umecheme
NorthEast
Re: Hull Repair
August 23, 2023, 03:30:45 PM »
Not many beaches here... The only dry spot I hope to encounter is the trailer!
August 23, 2023, 05:44:51 PM
Mwar410
Re: Hull Repair
August 23, 2023, 05:44:51 PM »
I wish I had a picture of the “beach I was on Monday, 50’ granite ledge that we had to land on.
1978 "170" 91' Yamaha 90hp
Mike
August 25, 2023, 10:12:28 AM
wingnut
Re: Hull Repair
August 25, 2023, 10:12:28 AM »
Yes, and if you find a small pocket of sand, you still don't beach on it... The rocks hide way too well in sand and seaweed! 12'+ tides will strand you quick too.
August 29, 2023, 12:37:35 PM
umecheme
NorthEast
Re: Hull Repair
Reply #9 on:
August 29, 2023, 12:37:35 PM »
20' tides here... you'd be HIGH and DRY for a while!
Hull Repair
