Author Topic: Minn kota quick release bracket questions and install '79 170  (Read 543 times)
May 18, 2023, 08:10:46 AM
Read 543 times
alandry100
So I finally caved and picked up a 80lb 60" Terrova and am in the process of installing.
My question is in the install of the quick release bracket. The bow area is not flat so I will need to shim somehow. I know many have done this but I have not seen photos or descriptions of what others have done.
I will post pictures of the situation when I get home.
79\' 170
2005 Yamaha 70 two stroke
May 18, 2023, 12:06:42 PM
May 19, 2023, 08:48:06 AM
alandry100
Re: Minn kota quick release bracket questions and install '79 170
« Reply #2 on: May 19, 2023, 08:48:06 AM »
Thanks for the response - I am using the RTA 17 bracket. I am going to try to avoid fabrication if possible. I am waffling between nylon and neoprene fender washer shims. Wondering what other folks have used to level out. I think I will need to raise the whole puck up a few mm's as the very bow of the boat forward of the old nav light is the highest point on mine. I need to raise the whole thing to clear. At that point the piece that is mounted on the motor will be lifted off the deck. Is this a problem? I'm thinking not as I have seen some motors that are more or less supported by only the puck.
79\' 170
May 19, 2023, 09:01:09 PM
« Reply #3 on: May 19, 2023, 09:01:09 PM »
I planned the same removable mount on my rebuild and added reinforcement on the front cap deck for mounting it. I have don't have the nads to pay $3k+ for the trolling motor that I desire. I have the install placement ready and the power already run to it, if I decide to buy.
May 20, 2023, 12:07:55 AM
alandry100
« Reply #4 on: May 20, 2023, 12:07:55 AM »
That’s some amazing foresight. I’m going to hope the core holds. I picked up a bunch of neoprene washers. Will level with those and sandwich with 4000.
79\' 170
May 20, 2023, 03:47:42 PM
Fish Head
  • MidWest
« Reply #5 on: May 20, 2023, 03:47:42 PM »
I stacked nylon washers accordingly to level on top of four neoprene washers to seal water out. Works great no issues last 2 years. I also used a plastic(poly?)cutting board from dollar store to reinforce from underneath! Cheers T
May 20, 2023, 06:22:32 PM
alandry100
« Reply #6 on: May 20, 2023, 06:22:32 PM »
I decided to go with neoprene spacers. Seems pretty solid. Will finish off the wiring tomorrow - then splash.
79\' 170
May 21, 2023, 05:13:46 AM
« Reply #7 on: May 21, 2023, 05:13:46 AM »
 :thumleft:
