Author Topic: 1975 Aquasport 22-2 Rebuild_PWH70  (Read 2897 times)
March 28, 2024, 08:43:30 AM
Reply #30
pwh70
  • NorthEast
Re: 1975 Aquasport 22-2 Rebuild_PWH70
« Reply #30 on: March 28, 2024, 08:43:30 AM »
I love the leaning post, Did someone local make that? please keep the progress reports coming!
Larro
Thanks, Larro - Yes, the leaning post was made locally (Eliot, ME), Bouchard Marine Fabrications. Jared is great to work with.
I got rid of the bulky fiberglass leaning post/livewell in favor of this one. He did a great job with it. It's sized for a slide-out cooler underneath. A slightly smaller livewell will be moved back to the closed-in transom area.
Meanwhile, I did find a photo with a slightly better view of the stringer area you were asking about.. from back when I was fitting deck pieces.
Thanks for looking, Paul
March 30, 2024, 07:22:08 AM
Reply #31
larro
« Reply #31 on: March 30, 2024, 07:22:08 AM »
Paul, thanks for the lead on the leaning post, the guy does quality work for sure! your project is looking great!
Larro
April 02, 2024, 12:54:32 PM
Reply #32
pwh70
  • NorthEast
« Reply #32 on: April 02, 2024, 12:54:32 PM »
It was arts and crafts day in Aquasport town...
Working on a mockup of the transom cabinet that will surround the livewell... this has been through a few versions, currently intending to mold a seat on either side, with storage underneath and access to the fuel separator and some plumbing behind everything. This is pretty boxy right now, things will be molded more smoothly when it's finalized.
The seats are a political move. They do occupy a bit of space back there, but since there has been very little pushback to the amount of time and money currently being dumped into this upgrade... I figured the finished product should have some improvement in comfort for my wife and friends for those evening sunset cruises.  :040:
I set the console and leaning post in place just to confirm the amount of space that will be available.
Thanks for looking - Paul
April 03, 2024, 06:19:01 AM
Reply #33
Gatorgrizz27
« Reply #33 on: April 03, 2024, 06:19:01 AM »
Nice work! The transom/bracket/rear seating/livewell is what Iā€™d eventually like to do with mine, even using that same tank. What are your plans for plumbing it?
Pretty amazing how as large as these boats are they came with so little functional storage. Lots of room for improvement in organization.
April 03, 2024, 09:06:49 AM
Reply #34
pwh70
  • NorthEast
« Reply #34 on: April 03, 2024, 09:06:49 AM »
You're right about that... I've added quite a bit of storage, almost all from ideas I've seen looking through this site.
All the way forward, I'm converting the bow bilge area to anchor storage and about 100' of anchor line. I added a bulkhead under the casting deck to define this area, which also reinforces the deck. It's the place where most people step pretty heavily into the boat when they're coming on from a dock, so the reinforcement will be good. For me, that frees up the entire wide hatch up forward (original fish locker) because that's where I kept the anchor and line previously.
I also added two long compartments on either side of the center console, outboard of each stringer. And a big storage compartment directly under the leaning post, behind the fuel tank and forward of the rear bilge. This one will be a little less convenient to get into, so will be a good spot for utility things, freeing up the other hatches for more frequently used stuff. And then finally the two smaller spots under the seating at the transom.
Regarding livewell plumbing - I don't fish with live bait a lot, so I'm not getting too fancy. There's a Johnson pump mounted directly onto the bilge seacock, which will feed the wash down pump and also supply a discharge directly into the livewell. My previous well had a second pump to assist the discharge out and over the transom. I was constantly trying to balance them. I'm hoping to properly size a gravity discharge opening at the top of the livewell, which will exit out through the transom. I'd like to avoid trying to balance two pumps if I can. No aeration or anything like that, my previous setup did ok without it. Just a circular water flow, in at the bottom and out through the top. The water stays pretty cold up here in NH, and the mackerel hold up for quite a while.
To drain the well empty, will just be a plug out the bottom that will drain the water onto the deck and out through the scuppers.
I'll include some pics when I get to mounting all of that.
April 04, 2024, 12:10:51 AM
Reply #35
pwh70
  • NorthEast
« Reply #35 on: April 04, 2024, 12:10:51 AM »
I feel like I should have more than this to show from today.
Major snowstorm here tonight/tomorrow... staying home and refusing to shovel a single inch of it.
A little more about this developing cabinet.. the livewell is sitting on a floor that is 4" above the deck. The bulkhead at the face of the livewell will have arched cutouts at deck level to allow any deck water to flow through and out the scuppers in the transom. There will be enough room to reach through and clean anything out if necessary.
The 4" floor will be the base of the storage cabinets under each seat (either side of the livewell). Each seatback cushion will have an access plate behind it, that when removed will provide access to the fuel/water separator, rigging, wash down pump, livewell plumbing etc... that will be mounted in or routed through the area between the cabinet and the face of the transom.
thanks for looking - Paul
July 01, 2024, 10:27:47 AM
Reply #36
pwh70
  • NorthEast
« Reply #36 on: July 01, 2024, 10:27:47 AM »
It's been a while since I've posted, but progress has been moving along (slowly).
I'm unable to post any pictures though, there seems to be an issue with the gallery portion of the site loading? Not sure if an Admin can check it out. Hard to describe what it's doing... displaying the ClassicAquasport logo stacked on top of itself about 30 times, and then basically times out and goes to a blank screen. I tried a couple different browsers with the same result.
Either way - the boat is currently getting the new Yamaha rigged and installed, I will post a couple months of progress in a few photos when I can access the gallery again.
thanks,
Paul
July 01, 2024, 11:49:35 AM
Reply #37
« Reply #37 on: July 01, 2024, 11:49:35 AM »
Woah, if your rigging already i would say that's fast work! LOL. The gallery is down and Rickk is working hard to get it fixed. Although not ideal, i think you can attach photos in the meantime.
1970ā€™ Flatback 222 - https://classicaquasport.com/smf/index.php?topic=15666.0
1981ā€™ Osprey 22-2 - https://classicaquasport.com/smf/index.php?topic=15249.0
1971ā€™ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
July 01, 2024, 03:09:31 PM
Reply #38
« Reply #38 on: July 01, 2024, 03:09:31 PM »
Paul, seems the server farm was struck by lightning and blew a few servers up, one of them was ours. We're working on the problem. In the meantime, as Ulysses mentioned, you can attach the pics - size the pics to 1024x768 and then attach them. Sorry for the inconvenience.
July 02, 2024, 05:34:13 PM
Reply #39
pwh70
  • NorthEast
« Reply #39 on: July 02, 2024, 05:34:13 PM »
Ok, testing an attached pic at 1024x768 (I think):
July 03, 2024, 05:59:19 AM
Reply #40
« Reply #40 on: July 03, 2024, 05:59:19 AM »
 :thumleft:
July 03, 2024, 07:55:46 AM
Reply #41
pwh70
  • NorthEast
« Reply #41 on: July 03, 2024, 07:55:46 AM »
It's been a while since I've narrated any progress, so I guess I'll just put some pics up for anyone's viewing enjoyment (or not!)  :D and people can comment or question if they'd like to.
Thanks for looking!
I modified the console to be able to flush mount my new Garmin MFD...
July 03, 2024, 07:57:12 AM
Reply #42
pwh70
  • NorthEast
« Reply #42 on: July 03, 2024, 07:57:12 AM »
Here's the anchor locker I mentioned in an earlier post:
July 03, 2024, 08:00:33 AM
Reply #43
pwh70
  • NorthEast
« Reply #43 on: July 03, 2024, 08:00:33 AM »
Some other interior pics, showing the back "cabinet" with center livewell and seats/storage on either side, there are some progress pics of this in earlier posts
July 03, 2024, 08:05:24 AM
Reply #44
pwh70
  • NorthEast
« Reply #44 on: July 03, 2024, 08:05:24 AM »
It's presently at the shop getting the new Yamaha F200 hung and rigged... then back to float it and establish the waterline, cap sanding/painting, rubrail, leaning post and T Top installation...
Thanks for looking,
Paul
