Author Topic: 1972 240 Transom  (Read 653 times)
March 30, 2023, 10:39:29 PM
Read 653 times
Captnbrody
1972 240 Transom
« on: March 30, 2023, 10:39:29 PM »
The existing boat was set up with i/o, I'm planing the re-build of the transom and i will be going with a porta bracket on the rounded transom. My thoughts are to enlarge the old i/o cut to 24" wide and extend it up to just above the upper mounting bracket of the porta bracket. I would use a 1/2' piece of coring material cut to fit inside the 24" cut out and then laminate it to the new coring on the inside of the transom. Another option would be cutting out the entire transom and forming one in flat, but i kind of like the rounded transom...All suggestions are welcome?
2018 East Cape Vantage VHP
1972 Aquasport 240 Sea Hunter
2009 Dusky 17 SOLD
March 31, 2023, 05:36:53 AM
Re: 1972 240 Transom
« Reply #1 on: March 31, 2023, 05:36:53 AM »
Here is a rebuild of a Family Fisherman that had a i/o.  Maybe he can give you some tips?
April 30, 2023, 07:32:02 PM
Captnbrody
« Reply #2 on: April 30, 2023, 07:32:02 PM »
 If anyone needs information on a porta bracket for a 4 stroke 250 hp-300 hp, this is the blueprint for it.
2009 Dusky 17 SOLD
May 01, 2023, 08:25:32 AM
« Reply #3 on: May 01, 2023, 08:25:32 AM »
That drawing is a good reference. I don't believe I have seen it before. However, it goes to a password protected link and it can be read on screen.
May 01, 2023, 08:29:04 AM
« Reply #4 on: May 01, 2023, 08:29:04 AM »
I would definitely keep the rounded transom and do whatever is necessary to build up a flat spot on the outside to thru bolt the porta bracket. I WISH I had the rounded transom. The other type built was not flat and will prove to be tricky during my rebuild.
May 01, 2023, 04:24:27 PM
« Reply #5 on: May 01, 2023, 04:24:27 PM »
Did I forget to add the link to the FF rebuild? Sorry.
https://classicaquasport.com/smf/index.php?topic=15553.0
May 01, 2023, 05:00:29 PM
« Reply #6 on: May 01, 2023, 05:00:29 PM »
The link goes to our photo gallery. He uploaded a pic and the gallery sized it. If he can email me the original I can upload the full size drawing. rickk@classicaquasport.com
May 01, 2023, 07:10:37 PM
Captnbrody
« Reply #7 on: May 01, 2023, 07:10:37 PM »
I’m definitely going to keep the rounded transom. Based on the cut sheet measurements I would need to create a 3/16” flat spot at the port and starboard edges. In other words it would go from 0 in the center to roughly 3/16” at the outside edge.
2009 Dusky 17 SOLD
May 01, 2023, 07:16:16 PM
Captnbrody
« Reply #8 on: May 01, 2023, 07:16:16 PM »
Sent…Keep in mind that bracket is for a transom height up to 36” and 300 hp.
2009 Dusky 17 SOLD
