A few questions/ thoughtsThere's about 1/2" of foam on the hull sides. Should I just remove it all? Not sure what the outer coating over it is. If I remove it all to bare fiberglass should I leave just bare fiberglass?
I plan on replacing the foam removed with 2lb foam between the stringers and hull side once cleaned up and I redo the stringer tabs. Would it make sense to to add additional support from the stringers to the hull side since the stringers are just foam filled and not wood or composite? I am just trying to make sure I don't miss anything when I get around to building back up.
Any recommendations on the type of putty to use for bonding the stringers to the bottom of the deck? The putty that was on there had a gelcoat look and smell when I was removing it. The gap between the deck and stringers is around an 1"or so thickness. Should it be a structural putty or will a GP putty work?
What would you recommend for replacing the plywood sections used to secure the cap screws on to the hull?Thanks
