Author Topic: 1969 Aquaport 19 running light restoration  (Read 393 times)
February 05, 2023, 09:43:22 AM
Read 393 times
hlobsta
« on: February 05, 2023, 09:43:22 AM »
Good morning..Its hard to believe I haven't been on the site for 6 years!
Last I posted I was looking for a chalk for my bow running lights..This search was successful.
I'm wondering if anyone has any insight on how I reinstall my running lights? its been so long, Ive
cant recall. Currently there is a more modern running light but id like original.
Ive enclosed pics if anyone can assist or direct me .
Thank you,
Hank
H Chadwick
February 05, 2023, 01:53:57 PM
Re: 1969 Aquaport 19 running light restoration
« Reply #1 on: February 05, 2023, 01:53:57 PM »
Time flies so first things first.
Can you disassemble the fixture?
No sense getting too deep in the weeds on wiring until you know the condition of the lamp base.
February 05, 2023, 04:02:35 PM
dbiscayne
« Reply #2 on: February 05, 2023, 04:02:35 PM »
vinegar works wonders on getting the green corrosion off parts like that. dilute w water 50/50 and let soak a few hours.
February 05, 2023, 04:04:45 PM
« Reply #3 on: February 05, 2023, 04:04:45 PM »
Any pictures of the bottom side of the fixture?
February 06, 2023, 12:44:53 PM
hlobsta
« Reply #4 on: February 06, 2023, 12:44:53 PM »
Good afternoon, I thought I sent both pics yesterday..Here it is apart. I'll take a pic of the underside.
M wondering how it attaches too the base on the bow?
H Chadwick
February 06, 2023, 01:17:17 PM
hlobsta
« Reply #5 on: February 06, 2023, 01:17:17 PM »
here are some more pics
H Chadwick
February 07, 2023, 05:32:44 AM
« Reply #6 on: February 07, 2023, 05:32:44 AM »
It looks like the top just sits on top of the bottom and the bottom is a spacer to allow some room for running the wires through the bottom of the upper piece. I think you take the top and bottom apart, then disassemble the top (2 screws) which exposes the lamp base and the bottom of the upper assembly.  remove the lamp base and that gives you access to holes that you can use for long screws to secure the whole assembly to the front deck, where there will be a hole that the wire runs up into the assembly. Sound feasible? The screw on the underside of the upper assembly is to ground the assembly and could also be one side of the connection to the lamp?  Can you disassemble the upper piece and take pics of that for us?
February 09, 2023, 02:39:33 PM
hlobsta
« Reply #7 on: February 09, 2023, 02:39:33 PM »
Hi, what you've  written does make sense. I need to uncover the bow of my boat and remove the current fixture to see the original mount.. Ive enclosed more pics as requested. thank you again foe assisting.
H Chadwick
