Author Topic: Thinking about buying 1989 20' Osprey...but...  (Read 261 times)
October 07, 2022, 09:57:08 AM
Read 261 times
jtc99
« on: October 07, 2022, 09:57:08 AM »
Hi All,
First post here.  I've been casually in the market for a boat for some time.  I usually go through the classifieds here / Craigslist / THT / FB Marketplace.  I happened upon a 1989 20' Osprey the town over from me on Craigslist.
Stats on the boat are
  • Model: Osprey
  • Length: 20'
  • Year: 1989
  • Number of Owners: Unknown
The seller wants to get the hull out of his driveway and has set a price of $1,500 OBO for the hull and trailer.
I was thinking of scooping this up, doing any cleanup (nothing structural, that is beyond me at this point), and getting a new engine (Suzuki 150) installed by a local Suzuki dealer who friends have worked with.
My concerns are
  • Unknown number of owners
  • The boat doesn't have a motor on it, so I am unsure of when it was last in the water
  • The owner is unsure of the condition of the fuel tank
The owner states that the transom is "rock solid," but would need to do a check when taking a look at the hull.
The biggest concern I have is the fuel tank.
Does anyone have any insight on some hazards of buying a 33 year old hull with a potentially old fuel tank?  Is there a way to inspect a fuel tank?  Thanks to rickk for sending over a the Used Aquasport Buyers Bible, which had some tips on fuel tank concerns, but I was wondering if there was an further insight on this from the wider Aquasport community?
Last thing I want to do is get this hull, find out it needs a major overhaul and turn this boat into a complete gut job, which is something I cannot facilitate, professionally ($$$$) or DIY.
Thanks all.
October 07, 2022, 01:20:37 PM
dbiscayne
Re: Thinking about buying 1989 20' Osprey...but...
« Reply #1 on: October 07, 2022, 01:20:37 PM »
proper way to test the tank would be a visual for obvious signs of corrosion, and also a pressure test to reveal non-obvious pin holes.
With that said, if the deck has a removable portion to access the tank you could assume the worst and plan on spending a few hundred for a Moeller plastic tank, plus $$$ for new fuel lines. If you're able to do that work yourself it won't be too much of an investment.
If theres not a removable access section of deck it'll be a lot more work.
October 07, 2022, 02:38:28 PM
jtc99
« Reply #2 on: October 07, 2022, 02:38:28 PM »
Thank you dbiscayne.  All great tips.
I was looking around the site / YouTube and there seem to be good tips on a fuel tank replacement.  Would be a first for me, but I'm not afraid to get my hands dirty and learn something new.
When I go and look at the hull I will see what kind of access panels are present.
