Author Topic: 1987 Osprey Fuel Tank replacement  (Read 599 times)
June 01, 2022, 11:00:39 AM
Read 599 times
InMaineWoods
« on: June 01, 2022, 11:00:39 AM »
I have a 1987 Osprey 200.  Awesome boat, repowered with Yamaha 115 HP several years ago.  The 33-year-old original fuel tank is DONE!.  I am looking for specifications/recommendations and sources for a replacement fuel tank.  I believe the original tank capacity is 65 gallons but I don't need all that capacity for summer seasonal running around.  Also, I am located in Maine so anything close by is appreciated.  Thanks!  Andy
June 01, 2022, 01:53:18 PM
dbiscayne
Re: 1987 Osprey Fuel Tank replacement
« Reply #1 on: June 01, 2022, 01:53:18 PM »
I had pretty good luck with Great Lakes Skipper, just search for Fuel Tank on their site, lots in stock.
https://www.greatlakesskipper.com/search/?q=fuel+tank
Also Moeller's website has good info on all the shapes/sizes they have available.
June 01, 2022, 04:00:57 PM
« Reply #2 on: June 01, 2022, 04:00:57 PM »
You may wish to contact Phil.
https://www.alloymetalworks.com/
He is a long time member and has many of the Aqua tank dimensions. He can also create a custom size.
August 15, 2022, 09:14:23 PM
Kefr
« Reply #3 on: August 15, 2022, 09:14:23 PM »
I am a new owner of a 1986 Osprey 170. How do I access ways to view the condition of the tank?
August 15, 2022, 09:54:49 PM
« Reply #4 on: August 15, 2022, 09:54:49 PM »
Best place to start is by pulling the hatch cover over the coffin.
This tells you the condition on the top and if there is moisture in the coffin.
Thing is, most pinhole corrosion is usually found on the lower/bottom portion of the tank. To check that, you need to pull the tank.
Hulls that old with the original tank often require replacement.
Good luck. :thumright:
