Author Topic: 1996 245 Exp  (Read 326 times)
May 26, 2022, 04:16:05 PM
Read 326 times
redtail14
  • FL - North Area
    • Deep Dive Spear Crew
1996 245 Exp
« on: May 26, 2022, 04:16:05 PM »
Hey ya'll! First time posting here!
 I'm looking at buying a 1996 245 Explorer. I'd like some info on the transom. I've read that they have a poured lower and wood upper.... maybe?? Anyone know for sure if that year had a solid poured transom? Any other info you can send my way on this model would be appreciated.
Max capacity for passengers? I haven't found capacity plate pic anywhere online.
Anyone that has this model please hollar...
Thanks!
May 26, 2022, 05:27:24 PM
Re: 1996 245 Exp
« Reply #1 on: May 26, 2022, 05:27:24 PM »
There was a transition time when they went from plywood to poured, we just can't give you an exact date/year. My '92 230 Explorer may or may not have a poured transom but it does have wood upper wings. By '96 I would think they all had poured transoms - depend on what Genmar was using for their lineup.
You can tap on the transom with a socket or pound on it with a rubber mallet. The Euro transom in '96 has all the "Euro" stuff in the back in front of the actual transom.
Only way to tell for sure is take an engine mounting bolt out and dig around in the hole.
May 28, 2022, 07:37:00 AM
redtail14
  • FL - North Area
Re: 1996 245 Exp
« Reply #2 on: May 28, 2022, 07:37:00 AM »
Appreciate the info 👍
May 28, 2022, 08:33:49 AM
Re: 1996 245 Exp
« Reply #3 on: May 28, 2022, 08:33:49 AM »
Gleaned from our Resource Forum.
https://classicaquasport.com/smf/index.php?topic=9149.msg136399#msg136399
Model year 2000 for the 245/250 is the same.
https://classicaquasport.com/smf/index.php?topic=9149.msg83579#msg83579
Note: Both the Osprey and Ex share the same capacity plates (labeled for the model itself). They are the same hull with different caps. The 250 is just a 245 with different decals. Same specs.
