Author Topic: merc ignition switch wiring diagram  (Read 2017 times)
April 28, 2022, 06:47:08 AM
Read 2017 times
Cpt. Beyond
« on: April 28, 2022, 06:47:08 AM »
i purchased a quicksilver 87-88107A5 ignition switch for use with my mid 90s 2stroke 90hp merc. It did not include any wiring diagrams for splicing to the existing ignition wiring harness. would anyone have a diagram handy for this particular wiring job? here are the wires im dealing with...
NEW IGNITION SWITCH
2 PURPLE (factory spliced)
2 BLACK, yellow stripe (factory spliced)
2 BLACK (factory spliced)
2 RED (factory spliced)
1 YELLOW, red stripe
1 YELLOW, black stripe
EXISTING IGNITION WIRING HARNESS (mid 90s 90hp 2stroke merc)
1 BLACK, yellow stripe
1 RED
1 BLACK
1 GREY
1 BROWN
1 PURPLE
April 28, 2022, 10:23:48 PM
Re: merc ignition switch wiring diagram
« Reply #1 on: April 28, 2022, 10:23:48 PM »
Does it look similar to this?
https://www.u-buy.com.ng/product/1AESB957S-boat-ignition-switch-with-key-replacement-for-mercury-mariner-outboard-motor-control-box-with-2-keys-3-position-6-wire-connectors-replace-mercury
Different brand(?) but it has the same color pattern you describe. If so, look at the photos on the left. One identifies the wiring.
best i could come up with tonight.
May 04, 2022, 06:29:49 AM
Cpt. Beyond
« Reply #2 on: May 04, 2022, 06:29:49 AM »
ok, it does look similar to mine except that on my new ignition i have 2 purples, 2 black with yellow stripe, 2 black and 2 red... if those 2nd wires of each pair are extra for future use, im not sure... i do think that diagram led me in the right direction though, this is what i came up with...
the old ignition has letter identifications next to the screw terminations... M, A&M ,C, S, B, I... there is also what i think is a round overheat buzzer wired to the I terminal, it then leaves with a brown and purple from round buzzer to motor...
I intend to splice onto the existing motor wiring harness with my new ignition switch using these letters on old ignition as identifiers...
From new ignition switch to existing wiring harness...
PURPLE TO I (with overheat buzzer installed in between switch and motor?)
RED TO B (install 20a in line fuse in between ignition switch and wiring harness splice?)
BLACK TO M
BLACK,yellow stripe TO A&M
YELLOW, red stripe TO S
YELLOW, black stripe TO C
the remaining grey wire coming from existing wiring harness appeared to have been connected to old tach or batt level guage...
would it appear i am on the right track?
thanks for the help
