Author Topic: wiring connections  (Read 281 times)
March 02, 2022, 06:27:26 AM
Read 281 times
Cpt. Beyond
wiring connections
« on: March 02, 2022, 06:27:26 AM »
hello,
 im getting close to wiring up my 82 170 and was wondering if anyone recommends using any anti corrosive agent on the connections to the instruments. i will be using terminations from west marine with heat shrink tubing built onto the connector. thanks again
March 02, 2022, 08:05:16 AM
Re: wiring connections
« Reply #1 on: March 02, 2022, 08:05:16 AM »
I would make all your connections clean and tight and when you're finished then I would apply a little bit of Di-electric grease on top of the connections to seal them up.
March 02, 2022, 10:40:34 PM
« Reply #2 on: March 02, 2022, 10:40:34 PM »
You may also consider using a spray coating like Corrosion X or Fluid Film on the connections. I had very good and long lasting results with both when applied to my various gauge connections.
Good luck. :thumright:
March 03, 2022, 05:00:11 AM
Cpt. Beyond
« Reply #3 on: March 03, 2022, 05:00:11 AM »
thanks for the advice fellas, will do
