Author Topic: FF 176 Fuel Tank  (Read 404 times)
February 03, 2022, 11:49:11 AM
Read 404 times
michaeln001
FF 176 Fuel Tank
« on: February 03, 2022, 11:49:11 AM »
Hello fellow aquasporters. I am replacing the fuel tank in my 1979 FF176. I would love to hear some opinions on the Mueller tanks. Has anyone installed them? It is a rather shallow compartment. Any problems with fittings? Thanks in advance for your advise.
February 07, 2022, 10:04:32 PM
boatnamesue
  • Jason
Re: FF 176 Fuel Tank
« Reply #1 on: February 07, 2022, 10:04:32 PM »
Not sure if the FF 17 has same tank dimensions as the CC 17, but if it does (56 x 20 x 6) then you won’t find a plastic tank with those dimensions on the market…..see this recent thread for ‘82 170.  Cheaper to have aluminum custom built to spec.
https://classicaquasport.com/smf/index.php?topic=15950.msg154689#msg154689
Jason
1976 AS 170
1998 S115TLRW
February 08, 2022, 12:02:01 PM
michaeln001
« Reply #2 on: February 08, 2022, 12:02:01 PM »
Thanks Jason. It is the same size as the cc17. Looks like I will have to have one made. Any suggestions where I could look for the specs with the location for the sending unit etc?
February 08, 2022, 04:43:35 PM
« Reply #3 on: February 08, 2022, 04:43:35 PM »
Michael, where are you located - shipping is expensive.
February 08, 2022, 05:26:28 PM
michaeln001
« Reply #4 on: February 08, 2022, 05:26:28 PM »
I am in New Hampshire. There is a local welder here who can fabricate the tank if I can provide the specs. Thanks for the help.
February 08, 2022, 07:10:21 PM
boatnamesue
  • Jason
« Reply #5 on: February 08, 2022, 07:10:21 PM »
I reconfirmed the specs on the invoice from the tank I had fabricated….56”x20”x6”  .125 AL.   As far as the specs for sender unit hole, I measured using the old tank I pulled out of hull.  Assuming you still have the old tank, I reckon that’s the most accurate method.
Jason
1976 AS 170
1998 S115TLRW
February 09, 2022, 01:12:31 PM
michaeln001
« Reply #6 on: February 09, 2022, 01:12:31 PM »
Thanks again. I got the boat without the tank so I am starting from scratch. I think I will wait until spring and get the boat opened up, pull up the floor panel and get the measurements there. There is an inspection port right above the sender that i can use for the location. Really appreciate your time and advise on this.
February 09, 2022, 03:43:33 PM
« Reply #7 on: February 09, 2022, 03:43:33 PM »
Michael you can reach out to Phil at Alloy Metal Works in NY. They were one of the OEMs used by Aquasport. You tell him what model you have and he'll probably have the original drawings. Worth a call.
https://www.alloymetalworks.com/home/4200848
February 09, 2022, 10:06:45 PM
boatnamesue
  • Jason
« Reply #8 on: February 09, 2022, 10:06:45 PM »
No problem.  There are a number of threads here to help you determine how to secure the tank….the modified pascoe method is a tried and true way if there isn’t straps already installed.
Jason
1976 AS 170
1998 S115TLRW
June 29, 2022, 04:06:42 PM
michaeln001
« Reply #9 on: June 29, 2022, 04:06:42 PM »
Hi Rick and Jason,
I just wanted to write and thank you for your good advise. I ordered the tank from metal alloy works in New York. It came in last week and fit like a glove. The guys at metal alloy works were awesome. The price was $425 and the tank came with the sender installed. I really appreciate your help.
Best,
Michael
June 30, 2022, 04:52:02 PM
« Reply #10 on: June 30, 2022, 04:52:02 PM »
Good to hear.
