Author Topic: ignition switch woes  (Read 306 times)
June 24, 2021, 09:48:15 PM
Read 306 times
oxlacey
« on: June 24, 2021, 09:48:15 PM »
The ignition switch plastic nut is cracked so it won't tighten.  I'm sure I'm on borrowed time.  Anyone know of a wiring diagram, part # for switch replacement, size of the plastic nut?  The key doesn't turn so easily either so is there something i can do to make the key turn easier?
June 25, 2021, 06:45:08 AM
Re: ignition switch woes
« Reply #1 on: June 25, 2021, 06:45:08 AM »
You can try liquid graphite. Put a couple drops on the key and slide it in and out of the slot. See if that helps, usually takes care of it.
June 25, 2021, 08:52:18 PM
« Reply #2 on: June 25, 2021, 08:52:18 PM »
What motor is it for? Wiring diagrams for the OMCs are fairly simple to follow and wiring up a new key switch is not too difficult to swap out. If the key doesn’t turn easily, I am wondering if corrosion is the cause?
1971’ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
July 01, 2021, 09:26:51 PM
oxlacey
« Reply #3 on: July 01, 2021, 09:26:51 PM »
ok, nothing tricky evidently.  3 wires to the ignition switch.  Hot (RED) goes to common.  Run (PURPLE).  Start (YELLOW).  I do have additional wires to the switch that I wish the Vendor had provided instruction:  yellow/stripe, black and another black wire.
