Aquasport Discussion
76 Aquasport 170 bow/anchor door
Topic: 76 Aquasport 170 bow/anchor door (Read 291 times)
June 14, 2021, 11:36:26 AM
Read 291 times
sowers22
June 14, 2021, 11:36:26 AM »
I've been looking threw older post on the forums to try and find a bow/anchor door for my 170.
Was there ever a cover on the bow from the factory?
Have any of you guys custom made doors for it and have pictures?
Sorry if the post in not in the right forum.
Thanks,
Josh
$ 1976 Aquasport 170 $
June 14, 2021, 01:53:46 PM
Mwar410
Re: 76 Aquasport 170 bow/anchor door
June 14, 2021, 01:53:46 PM »
Here’s mine I made out of some scrap teak
1978 "170" 91' Yamaha 90hp
Mike
June 14, 2021, 02:23:18 PM
sowers22
June 14, 2021, 02:23:18 PM »
Awesome, looks good!
How in the hell did you get the speakers installed up there?
Such a tight spot.
Guess i need to just make one like yours and also need to do the center console door/latch.
Cant seem to find anything that fits her.
June 14, 2021, 08:33:18 PM
boatnamesue
Jason
June 14, 2021, 08:33:18 PM »
The teak is a super nice solution. Another option that requires less effort is pictured below. I do recall having to widen the hatch access using a drimmel to squeeze in the hatch cover.
Jason
1976 AS 170
1998 S115TLRW
June 14, 2021, 08:53:23 PM
Mwar410
June 14, 2021, 08:53:23 PM »
Such a tight spot.
I pulled a bundle of wires up into the corner of the bow locker while I was running the new fuel lines. Pretty easy shot from the fuel coffin. That’s about as far back as you can go before it gets too tight.
Mike
June 15, 2021, 08:19:43 AM
sowers22
June 15, 2021, 08:19:43 AM »
Thanks guys.
I'll be working on mine this week will post some pictures maybe when finished!
June 17, 2021, 01:05:36 PM
sowers22
June 17, 2021, 01:05:36 PM »
Thanks for the motivation !!
Not to bad for just a jigsaw and a ton of sanding.
June 17, 2021, 05:21:57 PM
June 17, 2021, 05:21:57 PM »
I'm not sure plywood is a good choice for exposed marine environment. I used Brazilian Mahogany and it has held up for about 15 years. If it gets funky, a quick scruff with 120 grit and re-oil with tong oil.
June 18, 2021, 09:13:33 AM
sowers22
June 18, 2021, 09:13:33 AM »
Yes sir, it's just temporary until i get some teak or mahogany. (Maybe cedar?) Tired of looking at the hole, so hopefully this will last until winter time when the boat gets its new makeover. Even thought we don't seem to ever have much of a winter!
