Well Fred,
It looks a little rough to me. The cabin ports are not right and there is glass work that needs done. Are you up for that?
The JohnnyRude is a "looper" and they were strong running engines that loved fuel. They also didn't like to sit so you would also need to run through the carbs, fuel lines, T stats and impeller for starters. Again, is this something you can do?
Lastly, it's hard to see the trailer but I'm guessing like everything else, it too will need work.
Says it's in the Tally area. If you're still interested, find out where and I'll take a look. You're about 2.5 hrs. west so it could save you some fuel.
