Yes, anything from 11 to 17 volts will work. Below 11 volts, the unit will still work, but it will cause the output transistors to overheat if you transmit much. At about 9 volts, the unit will probably no longer operate if it has a microprocessor. However, I've seen these things continue to receive down to 6 volts - just don't count on it.
