So... quick question regarding thru hulls. I purchased a "standard" round stainless thru hull, with the expectation of installing it for a (future) livewell. My buddy told me that this will not work, and I need a clamshell type thru hull in order to suck water while underway. I can see creating an eductor effect from moving through the water. Is this the case, and if so, what should I be using for a thru hull fitting?
