Aquasport Discussion
Removing bow nav lights on a 2004 Osprey Sport
Topic: Removing bow nav lights on a 2004 Osprey Sport (Read 406 times)
March 30, 2021, 10:09:02 AM
Read 406 times
waynewk
NorthEast
March 30, 2021, 10:09:02 AM »
Newbie boat owner. Bow nav lights don't work. What is secret to removing bow light without casing damage. I don't see any screws to remove.
March 30, 2021, 11:36:28 AM
Re: Removing bow nav lights on a 2004 Osprey Sport
March 30, 2021, 11:36:28 AM »
You have a bow pulpit? Light on the very front of pulpit? Post up some close-up pics.
March 30, 2021, 11:38:34 AM
waynewk
NorthEast
March 30, 2021, 11:38:34 AM »
Don't have any pictures.
I'll take them this evening.
Thanks.
March 30, 2021, 03:48:42 PM
March 30, 2021, 03:48:42 PM »
If you want to post a pic when you talk about your boat, which you should, follow the instructions here
http://classicaquasport.com/smf/index.php?topic=12725.0
- don't attach them - you are limited by file size. Uploading them into your
"member gallery"
is better for viewing.
Spend a few minutes to absorb the instructions. It's really easy. Remember if using a phone to take pics, to hold the phone horizontal with the lens to the left.
April 01, 2021, 09:40:52 AM
waynewk
NorthEast
April 01, 2021, 09:40:52 AM »
RickK, thanks for the info.
I was able to get a better look at the bow nav lights and realized that there were two screws set into the black, plastic mounting bracket. They are discolored and set so they blended into the bracket with my limited view.
Like I said, a newbie.
April 01, 2021, 02:17:09 PM
April 01, 2021, 02:17:09 PM »
That makes it easy
May 26, 2021, 08:58:41 PM
waynewk
NorthEast
May 26, 2021, 08:58:41 PM »
So now that I have the nav lights figured out, is there any secret to getting the passenger lounger seat to lay flat? There is a knob under each seat which when loosened, allows the seats to slide forward or aft, however can’t figure how to get the seat to go down flat. Don’t want to force anything.
May 27, 2021, 07:25:45 AM
May 27, 2021, 07:25:45 AM »
Can't help you with that - sorry. Someone will pop in and help.
May 31, 2021, 07:26:49 AM
Global Moderator
May 31, 2021, 07:26:49 AM »
Never had them but I remember that you lifted the front facing seat up to clear the "box" and fold down the legs. Don't remember a handle/clasp/lock per sey just "friction fit. They could require a very firm tug/wiggle/shake if they had not been used for some time even in fresh water.
June 01, 2021, 03:56:27 PM
waynewk
NorthEast
Reply #9 on:
June 01, 2021, 03:56:27 PM »
Thanks will give it a try next week once onboard.
Wayne
