Author Topic: how heavy is the fuel tank access panel?  (Read 214 times)
March 29, 2021, 09:39:11 PM
Read 214 times
eddielg
  • Information Online
« on: March 29, 2021, 09:39:11 PM »
Removed fuel tank access floor panel today to inspect original 1983 fuel tank and almost dropped a nut. My panel is really heavy, guessing 80+/- lbs. Thinking its waterlogged, unless the factory built these panels out of Durock.
1983 Aquasport 200 XF
March 29, 2021, 10:43:45 PM
dbiscayne
Re: how heavy is the fuel tank access panel?
« Reply #1 on: March 29, 2021, 10:43:45 PM »
shouldn't be much heavier than an equivalent sized piece of 5/8 plywood, I'd bet the glass & gelcoat are about 10 lbs.
March 30, 2021, 08:32:08 PM
« Reply #2 on: March 30, 2021, 08:32:08 PM »
I remember mine  wasn't light... but not that heavy. Water gets in thru the screw holes. You know if the core was wet. Try drilling a hole into the core from the bottom. Pay attention to the saw dust.
