Gallery
Gallery
Miscellaneous Aquasport Hull Info
Cabin Models
94 245 explorer fish box
Topic: 94 245 explorer fish box (Read 41 times)
January 11, 2021, 11:11:40 AM
Read 41 times
domenchello
January 11, 2021, 11:11:40 AM »
My fish box fills with rain water rather quickly is this common, if so has anyone found a solution.
January 11, 2021, 07:23:00 PM
Global Moderator
Re: 94 245 explorer fish box
January 11, 2021, 07:23:00 PM »
This is from an old thread and a different model (215) but it may pertain to your concern.
The problem with insole fishboxes is that, although they have gutter drain channels that the hatch fits into, quite often they aren't deep enough. Thus, if you have a heavy downpour, the water flowing off the deck and into these gutters will be too much for the gutters to drain off and water will overflaow into the fishbox. A slight starboard list would obviously explain the situation you describe. Now one thing you can do to help get rid of this problem is to put a good neoprene gasket on top of the gutter drain dam to help the dam seal to the bottom of the hatch. Get some modelers clay and put some small pieces, about 3/4" tall on top of that gutter dam, then close the hatch. Open it back up and measure the height of the clay. This will tell you the gap between the dam and the hatch. If it's around a 3/8" or so we use this stuff made by
Trim-Lok
that works real well for us for the same purpose.
Cabin Models
