Author Topic: 246/250ccp closed transom  (Read 977 times)
December 23, 2020, 07:07:18 AM
Read 977 times
seafoamccp
« on: December 23, 2020, 07:07:18 AM »
I bought this 79 246ccp.  It needs floors and transom redone.  Is there any really good write ups on here for re doing the floors? also can anyone that has done a closed transom give me some info such as cost and time it took to do it. Is it worth it to do?  still trying to decide ifbi should stay open or add a bracket.  I use the boat for offshore fishing in the gulf of fl mainly
December 23, 2020, 06:28:14 PM
Re: 246/250ccp closed transom
« Reply #1 on: December 23, 2020, 06:28:14 PM »
mshugg just finished his CCP rebuild and closed in his transom, among other great mods. Look in the CCP rebuilds forum.
December 24, 2020, 02:31:35 PM
« Reply #2 on: December 24, 2020, 02:31:35 PM »
As mentioned above, I rebuilt my 200 CCP, enclosed the transom and added an Armstrong bracket.  It worked out great.  The full transom gives a great sense of security offshore, and I gained a ton of fishing room.  I relocated my bait well to the leaning post,  it on a 246 you’d have the option of building it into the transom cap.  It’s great to be able to brace thighs against the transom while putting out baits or fighting fish.  The cost for the  full transom won’t be much more than rebuilding a cut out.  New, a bracket will add 3-4K.
Be sure to post pictures. I look forward to following your rebuild.
February 23, 2021, 11:07:50 AM
seafoamccp
« Reply #3 on: February 23, 2021, 11:07:50 AM »
20210223_105017
My question right now is, am I going to have to cut the entire back of the boat out to enclose the transom?  I could see how I would do it if my transom were flat but it has a curve to it and the sides bend outward as well.
February 23, 2021, 11:11:02 AM
seafoamccp
« Reply #4 on: February 23, 2021, 11:11:02 AM »
June 20, 2024, 08:15:58 AM
« Reply #5 on: June 20, 2024, 08:15:58 AM »
I am having the same issues looking at my 246 cup transom. With minimal cutting of the existing outer wall and the inside gutted out the remaining transom is flexible enough to where it will give a little if under pressure. The real problem is the curve towards the lower quarter when looking from the side. The transom is not flat vertically. I am trying to mount a bracket so I need a flat spot. The solution… I think… will be to build a 4’ x 8’ platform… like a deck… and affix/strap/spit and glue the flat side of the platform to the outside of the transom, true the platform square and even, then build the transom from the inside against that shape. The deck would be 2x6 frame with 3/4 ply with 3/4 melamine board, waxed so glass/gel coat doesn’t stick. A large flat surface that I would press against the transom at the angle I want the transom to be. Unfortunately this idea is theoretical at the moment as I haven’t done it yet myself but I hope to try it in the fall and document on this site.
July 01, 2024, 11:59:04 PM
pat nanney
« Reply #6 on: July 01, 2024, 11:59:04 PM »
Did my 1978 245  enclosed trans installed twin engine bracket. ihave some ideas.on how i managed the curve .
August 27, 2024, 09:17:47 AM
« Reply #7 on: August 27, 2024, 09:17:47 AM »
Update on my R and D for 246CCP transom closure….
I built a 4’ by 8’ table top out of 2x6’s, 3/4 plywood and 3/4 melamine. Super stout and heavy.
The plan is add a sheet of Formica or 1/4 inch white board then bolt the entire assembly through the drain hole and press the assembly against the transom insuring a flat, true surface for the bracket. At a height of about 6” above the bracket in the photo I plan to curve the 1/4” sheet ONLY to meet the top edge then gel coat just the void  then glass the hell out of the opening adding larger and larger sheet until I have added a sheet that wraps at least a foot down the sides. It is not possible to continue flat all the way to the top cap. It has to be in two different angles but the bracket has to have a flat 13 degree even surface. The top portion just has to meet the cap for closure. Yes, there will still be a visible where the gel coat was added once the form is removed but I think that will leave me with a fairly easy transoms to body fill and final coat gel coat. I will then build an inner transom wall and use Seacast at a height of 6” above the bracket.
This is obviously theoretical at the moment but may end up happening by September 8th if I have enough time and material from laying the floor.
August 27, 2024, 09:34:15 AM
« Reply #8 on: August 27, 2024, 09:34:15 AM »
This is what I am planning. I will let you know in the coming weeks if it worked out this way. Theoretically you do not need the 3/4 melamine if it is strictly for a transom mold. I have it there becuase I am using it as a glassing table first before a transom mold. I may remove it because of the weight…. But you get the idea. Notice the relief at the top to match the existing lip of the hull.
September 22, 2024, 08:34:14 AM
cuz253
« Reply #9 on: September 22, 2024, 08:34:14 AM »
Hey, very interested. I'm looking to enclose the transome on my 250 CCP 0-8. I was thinking of using some type of mold and the existing notch transom skin plus some coosa or marine plywood. My plan is to strip away the old transom, leave the fiberglass skin if possible and fill the notch with either coosa or marine plywood. I would then have to fiberglass and tab the thing so it would be a whole single piece. Alternatively I was considering just building a mold and using seacast or carbon core to envelop and incorporate the fiberglass outershell into the full transom. How did your plan turn out? Thanks in advance, Dave
September 22, 2024, 10:40:44 AM
« Reply #10 on: September 22, 2024, 10:40:44 AM »
I should be tackling the outer skin before the winter so stay tuned. The challenge is that the existing outer skin is not flat as it is curved both vertical and horizontally so that adds a challenge if you want to use a flat board like coosa. Also the inside of the outer skin seems to be a merge of castings as the layers of fiberglass are very erratic. It’s going to be a monster ton of sanding to the skin ready. Basically my plan is to grind it flat, lay a form over the outside, gelcoat the form and lay glass first closing the opening working my way to laying glass full transom with 6” tabbed on both sides of 2808. The big form (my 2x6 table) will hold the form for the flat that I need for the motor bracket. The 1/4” board will be shaped to close off the rest. The 1/4” board will be held in place with shims to give it the shape I need. Unfortunately this is all in concept at the moment as I have not done this yet but I am on the final floor piece before I address the transom so it’s coming soon in the next few weeks
September 22, 2024, 12:54:24 PM
« Reply #11 on: September 22, 2024, 12:54:24 PM »
In addition… that’s why I have chosen seacast as it will conform to the existing shape
Of what ever is left of the cavity. Coosa or any flat board in my option is not idea as the cavity space of the transom will never be perfectly flat.  Seacast will obviously conform to whatever it there. Again untested opinion soon to be tested. I am not a pro just a talented over thinker.
