Author Topic: 1970 Flatback 222 - Barn find Revival  (Read 9893 times)
November 23, 2020, 01:30:12 AM
Read 9893 times
« on: November 23, 2020, 01:30:12 AM »
Hello CAS friends.
So this Flatback came across unexpectedly and was the reason for the sale of my 1971’. It was found in Miami, Fl in the Kendall area and it was noted (from the owner who salvaged it off the original owner) that it had not moved from where it sat for 40yrs!! The previous owner was doing work for an “old man in his 80s who got sick and was never able to use the boat” and took it on trade for work. The last trailer registration sticker present was from 1985. The condition of the trailer and hull appear as though the hull was under some form of canopy but still outside exposed to humidity. The deck and casting platform are rock solid short of a soft spot at the opening of the live well ...yes it has original viewing windows which I am really excited about.  :danceSm: The stringers seem solid and dry from what I can tell so far. There are no access ports cut in the deck. The transom is shot unfortunately. It’s all original Gelcoat, non skid deck, no bottom paint or paint anywhere. In fact, the Gelcoat at the hull bottom still shines and even the area around the viewing windows are in incredible shape.
Truly a time capsule and my goal is to keep it as original as I can. It definitely has stains that are going to keep me busy behind a pressure washer but should be a neat simple build. Finally, the Classic Flatback 222 with viewing windows that I always wanted. The dive platform would have been neat but i can’t complain.
I do like a good storyline and history but I am just as much a sucker for photo evidence so here are a few shots from the property it was pulled from and me moving it from the trailer so I can trailer it to north Florida.
Leaving the “old mans” property
Picking her up from the PO using a local wrecker.
In Homestead transferring her to a trailer with axles.
First pass of the pressure washer at home...unfortunately stopped working halfway through ..ugh.
November 23, 2020, 05:52:08 AM
Re: 1970 Flatback 222 - Barn find Revival
« Reply #1 on: November 23, 2020, 05:52:08 AM »
What a find - congrats. Is the transom flexing?
November 23, 2020, 08:30:46 AM
dbiscayne
« Reply #2 on: November 23, 2020, 08:30:46 AM »
great story & and boat, hope you get her back on the water! I came across a similar situation with my 19-1, but ants & whatever other little bugs had gotten into the deck core through loose screws & eaten away most of the plywood.
November 23, 2020, 01:26:40 PM
« Reply #3 on: November 23, 2020, 01:26:40 PM »
Thank You RickK.
The transom is surely shot. There is wood rot on the corners where the cap attachment meet and I can run a screwdriver down each side. I am hopeful that the chainsaw/poured method might work because i want to keep the deck in one piece and try my best not to cut up the scupper trough etc. I have no idea how I would accomplish this while also needing to replace the drain and scupper drains but time will tell how far I need to dig to make it right.
Although not the best of designs, I plan to use the in deck cable tray for rigging and the in console space for a 30 gallon fuel tank (leaving me room to possibly cutout an insulated cooler below the seat. I would like to stow the batteries in the "dry storage compartment" center forward of the console and wire through the deck side under the cap and back through the deck cable tray. My goal is to power it with either an older 2 Stroke 115hp Yamaha @ 330lbs or a 2 Stroke 90hp Yamaha at 261lbs.  I prefer the proportions of the 115hp to the boat and the extra power would be nice (only a slight concern about noise).  However, the 90hp seems just right for my goals. We had a 90 Yammy on a 17 Montauk Boston Whaler and that was a fun rig. With just me and half a tank of fuel i dont think the hull bottom was touching the surface of the water..lol.
I plan to use it inshore out of Crystal River, Waccasassa, Ingles, Homosassa, and Silver Springs, etc. for family cruises and Hunting Redfish and ....Grouper?. I would also trailer it to South Florida for spearfishing and lobstering during the summer and bottom fishing in the bay with the boys when they are older.
I surely hope that I don't end up with a similar situation. However, at the end of the day, if I absolutely have to replace the deck, I would consider it a perfect platform for a rebuild.
Stay tuned :)
November 23, 2020, 03:03:49 PM
« Reply #4 on: November 23, 2020, 03:03:49 PM »
Look through Lar's rebuild - he used Seacast and it came out great. PM him with questions. https://classicaquasport.com/smf/index.php?topic=12508.0
November 25, 2020, 08:45:42 PM
« Reply #5 on: November 25, 2020, 08:45:42 PM »
Thank you for point this one out. I have gone through some of his post in the past and went through most of the other day when you pointed it out. We shall see. :)
December 15, 2020, 01:45:22 PM
« Reply #6 on: December 15, 2020, 01:45:22 PM »
So I was able to do a scupper/buoyance/float test this past weekend!! I was anxious to get a baseline for the hull and original motor hanging on the back. Unfortunately/fortunately..haha, the scuppers only barely sat below the waterline. However, that was with me standing back (three batteries in front of the console). When the three batteries were placed aft, it was the same condition with me forward but when I walked back, water rushed into the rigging track to a point and stopped. I did some rough leveling and figuring (unfortunately not till I was home because I forgot a level) and I might gain 1-3 inches if I can get weight forward to bring the hull closer to level....which brings me to my questions.....is there a design angle that is best for flat bottom boats that is used? Because these flatbacks don't have lifting strikes and primarily only "move forward faster" while using their sharp entry bow to cut the chop, wouldn't an almost perfectly level hull be a good thing (aside from a wetter ride)? I guess its a matter of whether its worth running the risk of having to trim up to raise the bow (running the risk to cavitate/roll on the keel) for a dryer ride? I am sure most are thinking tojust rip the deck out, close the transom, and raise the deck, but my goal is simplicity (and the deck is solid and stringers are dry - as far as I can tell). However, I am between a 140hp Suzuki @ 405lbs, a 115hp Yamaha @ 377lbs, a 115hp Merc. @ 359lbs, 150hp Merc. @ 455lbs, 150 Yamaha @ 489lbs. This is all in comparison to an original 135hp Evinrude that weighs a solid 270-300lbs. The only motor that compares is the 90hp 2 Stroke but I am having a hard time with the emission and racket of what would come with the 2 stroke cruising down a quiet fresh water river (Silver Springs / Ocklawaha) with the family.
Standing in front of the transom with three (3) batteries in front of the console.
Thoughts?
December 15, 2020, 02:57:20 PM
« Reply #7 on: December 15, 2020, 02:57:20 PM »
We have a couple members who are fishing guides with a FB and have a 150 on theirs - one is a Honda and the other with a Merc Opti (He said it was perfect for the hull). Doesn't look like Merc makes a 2-stroke anymore. Maybe only the ETEC is a 2-stroke.
If you can find a 90-115 stroke, that would move the boat along nicely. I drove one with a 90 and it was enough power. Depends how much power you feel you need.  One of our members had a 225 or 250 on his - he said it was scary.  ::o:
December 15, 2020, 03:11:04 PM
« Reply #8 on: December 15, 2020, 03:11:04 PM »
This is a drawing from the gallery. Your boat doesn't look much off the lines shown in the drawing
December 17, 2020, 02:07:53 PM
« Reply #9 on: December 17, 2020, 02:07:53 PM »
Rickk, good point. I totally forgot and haven't had the chance to reference back to this. It was indeed the same as this stock/factory photo. :)
Its puzzles me though how the trough system was built so low at the lowest point of the rigging tray. It was inevitable for water to constantly sit in the rigging tray when fishing with a couple of adults out back. I guess plugs are in the cards for me.
December 23, 2020, 08:10:13 PM
« Reply #10 on: December 23, 2020, 08:10:13 PM »
Curious if it’s possible to replace coring in transom from removing outside skin, not impacting inside skin, floor, and gutter/trough. Not sure if chainsaw/Poured transom would be easier than the fairing necessary with cutting the exterior skin. Thoughts? Thank you
December 24, 2020, 05:24:09 AM
« Reply #11 on: December 24, 2020, 05:24:09 AM »
The danger when pouring a transom is any leaks that would allow the material into the bilge area. I don't know if there is some kind of bag you can insert into the gap and then pour into the bag?
December 26, 2020, 01:04:24 PM
Sambam430
« Reply #12 on: December 26, 2020, 01:04:24 PM »
Poured my transom, very little fairing needed after laying up fiberglass with melamine board. But I also made a new inside skin which I made for the inside and fiberglassed in prior to pouring Arjay 6011 I didn’t wanna use the original fiberglass. Just had to fair the outside seams that I filled and covered with 1708. The rest of the transom was smooth.
December 27, 2020, 12:39:47 PM
« Reply #13 on: December 27, 2020, 12:39:47 PM »
I never thought of this as an option but seems like I could benefit from both. Easy cleanup, and less fairing, all from the outside. Maybe recess the MDF where is meets the exterior skin? How did you tie in the exterior skin to the pour? Thanks for your input!
December 29, 2020, 09:45:15 AM
Sambam430
« Reply #14 on: December 29, 2020, 09:45:15 AM »
I made small square spacers out of the Arjay 6011 at my desired thickness about 2 inches and installed them spaced out throughout the inside of transom so I would have even thickness. Got this idea from Seacasts website. The inside skin I made a template layed it out on the same melamine board after it cured, I popped it off cut it to shape, grinded the inside skins on both sides so when I poured it would have a good mechanical bond when cured. I also ruffed up the spacers just to be sure. With the inside skin against the spacers, I was able to do over lapping layers of 1708 longer and longer to complete the bond to the hull. I made a homemade large funnel that sat inside the transom gap out of cardboard and duck tape to make pouring easier, I did the pour myself in no time. Just make sure you support the outside and inside of the transom well to prevent bulging or possibly failure. The exotherm is pretty crazy. I had my knees installed prior to the pour that way the inside was supported, and the outside I supported with 2x4’s fastened to the outside every so many inches to make sure I was good to go. Stuff is expensive and didn’t wanna make an expensive mistake.
