Author Topic: '79 Aquasport 170 Rebuild  (Read 1776 times)
October 12, 2020, 05:08:42 PM
Reply #30
cduck870
Re: '79 Aquasport 170 Rebuild
« Reply #30 on: October 12, 2020, 05:08:42 PM »
I have uploaded to my gallery the screen I get. Maybe I am missing an update to the site?
October 12, 2020, 07:38:16 PM
Reply #31
« Reply #31 on: October 12, 2020, 07:38:16 PM »
Only Admin and Moderators can delete pics. We've had people go in and by mistake delete their entire gallery, which wipe out all the pics in their topic. OOOOPS! I can delete the pics, let me know which one(s) you want deleted. If it is a duplicate name I don't think I can delete just one.  You have several that are name the same - we can't rename them either since the system thinks they are one.
October 12, 2020, 09:58:30 PM
Reply #32
« Reply #32 on: October 12, 2020, 09:58:30 PM »
My bad.
Sorry for the mis-information. :embar:
October 13, 2020, 11:28:53 AM
Reply #33
cduck870
« Reply #33 on: October 13, 2020, 11:28:53 AM »
Now I understand. Thanks for the information. I will update my gallery and rename
Some and get back with you. You guys are very helpful. Thanks again for
Sticking with me on this
October 14, 2020, 05:56:30 AM
Reply #34
« Reply #34 on: October 14, 2020, 05:56:30 AM »
Well, decision made. Liner is out on starboard side. Any suggestions on type of glass and
And how many layers would be appreciated. Pictures are on the gallery. I can’t figure how to move
Them here.  Ok with boats, not to much with technology. LOL
Posting pics in topic - You have the pics in your gallery, that was the hard part. Now follow from step 8 in this thread to copy the IMG code from the gallery and post into your topic. It is best to open two tabs in your browser, one to your topic and one to your gallery in the photo gallery.
https://classicaquasport.com/smf/index.php?topic=12725.0
You asked about glass: What is your rebuild plan as far as resin? Are you planning you laminate a layer onto the hull sides and down to the first stringer?
Did you save what you cut out of the liner so you can glass it back in?
What is your plan for finishing the inside of the boat - gelcoat or paint?
If you are planning to use epoxy to laminate the hull but had planned to use poly resin so you can gelcoat, you can do this if you saved the liner. You use epoxy for the strength and then cover it visually with the liner, which usually does not attach to the hull. It even allows you to install the new floor all the way out to the hull sides, connect to the hullside with epoxy and then hide that connection with the liner. I used epoxy below the floor and poly above.
