Flatback 22-2 Rebuilds
dmont's flatback build
Topic: dmont's flatback build (Read 4316 times)
September 01, 2022, 08:51:16 PM
Reply #45
Re: dmont's flatback build
Reply #45 on:
September 01, 2022, 08:51:16 PM »
Man that profile pic looks good. What setback JP did you get?
September 02, 2022, 07:31:24 AM
Reply #46
dmont
Reply #46 on:
September 02, 2022, 07:31:24 AM »
It is a 10" set back. I think it will work good for me. In that picture the jack plate is in the lowest position.
September 02, 2022, 05:09:51 PM
Reply #47
Reply #47 on:
September 02, 2022, 05:09:51 PM »
Looks like you can get powerhead up and over the transom while tilting it. What is the travel of the JP? 6 or 10"? Looks like 6"
September 02, 2022, 06:35:43 PM
Reply #48
dmont
Reply #48 on:
September 02, 2022, 06:35:43 PM »
I believe the travel is 5 or 6".
September 03, 2022, 05:05:03 PM
Reply #49
Reply #49 on:
September 03, 2022, 05:05:03 PM »
Looks like you raised the engine mounting up an inch for the setback
September 04, 2022, 07:43:24 AM
Reply #50
dmont
Reply #50 on:
September 04, 2022, 07:43:24 AM »
Yes, I was shooting for having the cavitation plate about 1" higher than the bottom of the boat. Hopefully this works out good. Easy to unbolt the motor from the jack plate if it does need adjustment. I did hang the motor on the next to highest bolt hole for steering clearance reasons also.
September 05, 2022, 08:04:54 AM
Reply #51
Reply #51 on:
September 05, 2022, 08:04:54 AM »
Getting close! 👍
September 19, 2022, 08:45:42 AM
Reply #52
dmont
Reply #52 on:
September 19, 2022, 08:45:42 AM »
Water test complete! The boat did great. Very happy with how it came out. The waterline of the boat came out just about perfect and the scuppers are 1-2" above the waterline. I'm sure with a big load I will need to plug them, but that is ok with me. Only had to make one adjustment on the water, the throttle cable needed to be adjusted a little to reach full throttle. Other than that no issues and the boat ran great through some of our normal chop. The boat planed out great and no porpoising. Very happy with how she performed. No idea on speed yet, but it felt good!
Now I need to mount a few accessories like rod holders and cup holders, and pick up a depth finder/GPS combo.
September 19, 2022, 06:49:41 PM
Reply #53
Reply #53 on:
September 19, 2022, 06:49:41 PM »
Looks great!! Nice work! Thanks for sharing. What kind of load is this with? Gallons of fuel …and how batteries are distributed around the boat? Assume 2 batteries inside the console? How long is the console and how far is the back edge of it from the transom inside skin?
Thank You!
1974' 240 CC -
https://classicaquasport.com/smf/index.php?topic=15975.0
1970’ Flatback 222 -
https://classicaquasport.com/smf/index.php?topic=15666.0
1981’ Osprey 22-2 -
https://classicaquasport.com/smf/index.php?topic=15249.0
1971’ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
September 20, 2022, 10:08:07 AM
Reply #54
dmont
Reply #54 on:
September 20, 2022, 10:08:07 AM »
I had 25 gallons of gas in (40 gal tank). There is one battery in the console. Console is 26" long. I will have to check on the distance from console to transom.
September 21, 2022, 06:43:50 AM
Reply #55
Nates 86 200
Reply #55 on:
September 21, 2022, 06:43:50 AM »
Great Job and congratulations on the completion of the boat. I love the idea that you kept it simple.
September 21, 2022, 10:19:53 AM
Reply #56
dmont
Reply #56 on:
September 21, 2022, 10:19:53 AM »
Thanks Nate. I wanted something that could fish/shrimp/crab hard but still have a decent look. I tried to make everything easy to work on and simple too.
January 11, 2023, 11:54:29 AM
Reply #57
Reply #57 on:
January 11, 2023, 11:54:29 AM »
Hey dmont,
Id be curious to see how things are going with the new build. I am planning a similar build keeping it simply but might add a little more weight in the way of a 4-stroke motor and small 4'' jack plate. How is the honeycomb material feel on your feet?
Thank You
1974' 240 CC -
1981’ Osprey 22-2 -
January 14, 2023, 10:04:36 AM
Reply #58
dmont
Reply #58 on:
January 14, 2023, 10:04:36 AM »
The honeycomb is solid. I put one layer of 1708 over the bottom and two over the top, with an extra layer over areas that were not well supported. I also put 6" tape over all the joints. No flex at all, even over the fuel tank where the deck is not supported. Also distance from back of console to transom is 77" measured along the deck.
