Author Topic: ethanol fuel in 1995 johnson 130  (Read 185 times)
September 04, 2020, 02:38:27 PM
Read 185 times
long john
« on: September 04, 2020, 02:38:27 PM »
hello everyone, I have a 1995 auquasport 200 that came with 1995 johnson 130, and I replaced all of the fuel lines and fuel pump recently, i also have a plastic built in gas tank that is about 45 gallons, I was wondering if I ought to use ethanol free gas from wawa or just use regular gas? my brother had a e-tec motor that a fuel injector failed because of a piece of rubber clogged it, but mine is a carburated motor so I dont feel like the degradation of the fuel line should hurt.  thanks in advance,   long john
September 04, 2020, 03:09:15 PM
Re: ethanol fuel in 1995 johnson 130
« Reply #1 on: September 04, 2020, 03:09:15 PM »
Don't use ethanol fuel!  It's not just the engine - it will gel in the fuel tank also.  Just... Don't do it!
https://www.youtube.com/watch?v=ZKhqL3xS0Dw
 :danceSm: :danceSm: :danceSm:
September 05, 2020, 07:02:47 AM
« Reply #2 on: September 05, 2020, 07:02:47 AM »
Wawa sells non-ethanol gas (at least here in FL). Ethanol is a solvent and will start eating everything up.  Plus it attracts water.
