Author Topic: cracked stringer  (Read 6141 times)
December 18, 2006, 11:18:18 PM
Reply #60
russell1
« Reply #60 on: December 18, 2006, 11:18:18 PM »
here's a before pic of my console   http://i104.photobucket.com/albums/m195 ... oat002.jpg
December 18, 2006, 11:20:36 PM
Reply #61
russell1
« Reply #61 on: December 18, 2006, 11:20:36 PM »
this picture makes me worry about what learks behind the crack and the nice job the last owner did on the tape pin stripe job  http://i104.photobucket.com/albums/m195 ... oat010.jpg
December 18, 2006, 11:33:29 PM
Reply #62
russell1
« Reply #62 on: December 18, 2006, 11:33:29 PM »
here is a picture of the one hatch I,m not using that covers the window area  http://i104.photobucket.com/albums/m195 ... 1/boat.jpg
December 18, 2006, 11:37:39 PM
Reply #63
russell1
« Reply #63 on: December 18, 2006, 11:37:39 PM »
here is a above shot of the floor after after gel coating and the glass beads..http://i104.photobucket.com/albums/m195 ... oat011.jpg
December 19, 2006, 05:16:09 AM
Reply #64
« Reply #64 on: December 19, 2006, 05:16:09 AM »
Quote from: "russell1"
http://i104.photobucket.com/albums/m195/baby156921/boat006.jpg    thats a test picture,which is floor after glassing
Ok Russell - you have the pix where they should be, at least until we get our gallery fixed.  The only thing you need to do now is copy the correct line to paste into your post.
If posting a pic from Photobucket you want to copy this line:
If posting a pic from our gallery, you copy and paste this line:
[Sorry Jim, I would have copied from my gallery but it isn't there anymore  :?:  :?: ]
There are some buttons on your post that are useful too:
The "X" deletes your post, the "Edit" button allows you to edit your post and the "Quote" button allows you to quote your own entry.
To edit the posts you have made so far on this thread, go to each one and click "Edit".  To make the pix you have posted "Appear" in the thread instead of just the link you have 2 options:
1) delete the URL (that's the http://.... code) you posted and go back to Photobucket, copy the IMG line and paste back into the thread OR
2) enter at the end of the URL already posted.  You don't have to click "URL" or anything - when you click save and relook at your post, your pix will now "appear". The UBBcode line in the 2nd pic above is how your completed code lines should look.
I would do the latter, if you want to.
Hope this helps not only you but anyone wanting to post pix in their threads.
December 19, 2006, 05:36:46 AM
Reply #65
« Reply #65 on: December 19, 2006, 05:36:46 AM »
Here ya go - I'll fix this one for you - NICE WORK by the way :D
December 19, 2006, 08:03:23 AM
Reply #66
warthog5
« Reply #66 on: December 19, 2006, 08:03:23 AM »
OK Rick. Now that you have been shown on Photobucket which line to copy/paste. The 3rd line under the pix you want.
On the pix's click on "Edit".  Then click on "resize" you will see a drop down box with 4 diffrent size's on it. Pick the one that says
"Message Board 640X480" That is the correct size.
The pix's you have posted don't need to be changed on CAS. Just edit the size on PhotoBucket and the size of the image will change on CAS. You will need to hit the page refresh button on CAS if you have the page still open. Then you will see the change.
