mshugg - Yes, its a ccp - 20 feet, 2 inches I believe is what it says on the title.Any tricks on adding pictures? Every time it says the file is too large
Wow, lots of progress!!!I think I would use a Sterling blade on a jig saw and cut the splashwell out carefully so you can get to the transom. You can glass it back together later. Get good measurements across the hull before the cut and attach a 2x2 or 2x4 across the gunwale tops at rear above the transom. It doesn't look like the factory ran the core across the entire transom, that's strange. Personally I would run the new core across the entire transom and tie it into the hullsides and bottom. My $.02BTW, was that trough to the starboard aft from the console a factory install? I've not seen that in all the years I've been on this site.
NewGuy your boat looks really clean. It looks like it was never painted, bottom or otherwise. That should save you lots of time and money. My 1979 200 CCP had a similar trough, but since it is glassed to the floor and lacks the screwed down cover (like 170/196), it’s not obvious. I cut mine up and threw it away with my rotted deck.I have no idea about what to expect to pay for a transom rebuild. I suspect there is a lot of variation depending on where you’re located. You may be able to get an idea by costing out materials, and estimating 15 to 20 hours labor at whatever shop rates are in you’re area.
2 pound foam is perfect for flotation foam if you need to re-foam inside your stringers, 4;pound is better there. That’s how she left the factory. If you foam after the floor is down, you’ll have holes to fill in the deck, plus you’re likely to have voids. It’s probably better to pour the foam before you lay the floor, level it, and if you’re cautious seal it prior to seating the deck. The bond between deck and stringers and the sides is much more important than the foam bonding to underside of deck.
