Author Topic: System Check Gauge alarm  (Read 328 times)
July 27, 2020, 07:39:36 PM
Read 328 times
Grizzly65
« on: July 27, 2020, 07:39:36 PM »
I got my system check gauge working but my alarm disk is disconnected. Does anyone know where I hook the red and black wires into to get it to operate? Do I splice into the power and ground wire running to the gauges harness? Any help would be appreciated.
July 28, 2020, 07:29:14 AM
Re: System Check Gauge alarm
« Reply #1 on: July 28, 2020, 07:29:14 AM »
Grizz,
Do you have a schematic? Seems to me the buzzer wire on an OMC was tan. :ScrChin:
It's a 97 200hp correct?
July 28, 2020, 10:31:47 AM
Grizzly65
« Reply #2 on: July 28, 2020, 10:31:47 AM »
Yes, 200HP 97 Johnson. The harness is hooked up, but I guess when I pulled the old guage the buzzer mechanism came loose before I could see where they attached. I attached the buzzer/beeper straight to the battery and it works. It is the black disc with only a small diameter red and black wire coming out. On the back of the new gauge there are to small holes that have an "I" and "S" are they supposed to push into there?
July 28, 2020, 10:50:43 AM
Grizzly65
« Reply #3 on: July 28, 2020, 10:50:43 AM »
I found a schematic that says Tan w/Blue is the alarm wire. So I would figure that the black wire will tie into it and the red wire into the violet (power) wire. Now, how to do that, splice connector?
July 30, 2020, 10:34:19 AM
Grizzly65
« Reply #4 on: July 30, 2020, 10:34:19 AM »
Got it done.
