Flatback 22-2 Rebuilds
Starting rebuild on 22-2...1968?
Topic: Starting rebuild on 22-2...1968? (Read 995 times)
July 12, 2020, 05:01:47 PM
Read 995 times
Matt76
July 12, 2020, 05:01:47 PM »
Picked up this flatback for free!! Put new axle, wheel bearings, wheels and some new u bolts.
July 12, 2020, 05:18:14 PM
Re: Starting rebuild on 22-2...1968?
July 12, 2020, 05:18:14 PM »
We'll be following and helping where we can.
If you want to post a pic when you talk about your boat, which you should, follow the instructions here
http://classicaquasport.com/smf/index.php?topic=12725.0
- don't attach them - you are limited by file size. Uploading them into your
"member gallery"
is better for viewing.
Spend a few minutes to absorb the instructions. It's really easy. Remember if using a phone to take pics, to hold the phone horizontal with the lens to the left.
July 12, 2020, 06:44:58 PM
July 12, 2020, 06:44:58 PM »
Not a bad deal! :) Lets see some more photos of the outside! :)
Ulysses
1974' 240 CC -
https://classicaquasport.com/smf/index.php?topic=15975.0
1970’ Flatback 222 -
https://classicaquasport.com/smf/index.php?topic=15666.0
1981’ Osprey 22-2 -
https://classicaquasport.com/smf/index.php?topic=15249.0
1971’ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
July 12, 2020, 07:31:24 PM
Matt76
July 12, 2020, 07:31:24 PM »
More pictures
July 13, 2020, 12:36:32 PM
Matt76
July 13, 2020, 12:36:32 PM »
Starting a 22-2 rebuild. Not sure what year. 1968-69 I believe.
July 13, 2020, 12:52:40 PM
July 13, 2020, 12:52:40 PM »
Ok Matt, I merged your two threads so you don't have to keep updating both. Post all progress and questions in this thread please.
July 13, 2020, 12:55:22 PM
Matt76
July 13, 2020, 12:55:22 PM »
You got it. Thanks Rick!
July 13, 2020, 01:00:24 PM
July 13, 2020, 01:00:24 PM »
And then I moved it into the right sub forum - you should be good to go now.
July 13, 2020, 01:12:38 PM
July 13, 2020, 01:12:38 PM »
Did you find any plastic plates in the boat , maybe on the console or on the inside of the transom?
Like this maybe?
July 13, 2020, 02:23:43 PM
Matt76
Reply #9 on:
July 13, 2020, 02:23:43 PM »
Not clear
July 14, 2020, 06:20:46 AM
Reply #10 on:
July 14, 2020, 06:20:46 AM »
Matt - The proper way to take a pic for a web site is to hold the phone with the phone horizontal with the camera lens to the left. Left handed people typically hold the phone opposite since their left hand is the touch to take the pic. Unfortunately websites display that pic upside down.
If you upload the pics to your free member gallery here, you don't need to size them, the gallery will size them properly for you. Follow instructions here
July 17, 2020, 05:21:17 PM
Matt76
Reply #11 on:
July 17, 2020, 05:21:17 PM »
Transom and stringers
July 17, 2020, 05:22:59 PM
Matt76
Reply #12 on:
July 17, 2020, 05:22:59 PM »
Stringers . Looks like i can cut tabbing of rest of stringers and save them. Fiberglass tabbing in between the stringers delaminated from hull. Should i support boat before any more demolition?
July 17, 2020, 08:38:05 PM
Reply #13 on:
July 17, 2020, 08:38:05 PM »
Free?! You're ahead of the game already. If you want to bail out before you get too far I'll give you $100 for it.
If you plan to take the stringers out then now would be the time to support it. If your plan is to just tab them back down one at a time then you should be ok with it on the trailer.
July 17, 2020, 09:25:05 PM
Matt76
Reply #14 on:
July 17, 2020, 09:25:05 PM »
Free. Only way I will be able to have a boat. Money will go towards engine. Not tabbing in. Removing stringers and saving. Remove old water logged foam . Layer of glass then put stringers back with new foam.
