Author Topic: 2003 205 Osprey  (Read 230 times)
June 30, 2020, 02:26:58 PM
Read 230 times
Sail2power
2003 205 Osprey
« on: June 30, 2020, 02:26:58 PM »
I am new to the forum and glad to be on board. I just purchased a 2003 205 Osprey and have many questions about this boat. First , when I was cleaning it up for its time I noticed that the cockpit drains where not draining along with the fish boxes. I thought they where full of debris, but after looking at the thru hulls they had been plugged off with what looks like a rubber plug. Why would you do this ? Thanks sail2motor
July 01, 2020, 10:12:05 AM
  • Information Online
Re: 2003 205 Osprey
« Reply #1 on: July 01, 2020, 10:12:05 AM »
Maybe it is a check valve, allowing water to go through only one way?
July 01, 2020, 01:18:37 PM
maropsdvr
  • Jim
Re: 2003 205 Osprey
« Reply #2 on: July 01, 2020, 01:18:37 PM »
If it's truly a plug, sometimes you would plug the one box so that the other can get pumped out by the livewell switch.  Mine has the one box and the livewell tee-ed off together and getting drained by the macerator.  the other does not.  Also, I've known some who plug the thru-holes to keep from having stuff get into them during the winter, but they remove them in the spring.
2000 Aquasport 215 Explorer
July 01, 2020, 04:46:51 PM
Sail2power
Re: 2003 205 Osprey
« Reply #3 on: July 01, 2020, 04:46:51 PM »
Thanks for the info. I am go to pull the hoses off the thru hulls and pull the thru hulls out. I will find out what is going on. Thanks
July 03, 2020, 10:58:40 AM
Sail2power
Re: 2003 205 Osprey
« Reply #4 on: July 03, 2020, 10:58:40 AM »
Good morning All,
After looking at my drainage problems with my cockpit and fish boxes, I was hoping I could find a 205 to look at to see how the drains really work. I am on the west coast go Florida in the Tampa Bay Area.
Well back to work on checking out the Electrical end of this boat. Have a safe and happy 4th . Thanks Sail2power
July 03, 2020, 12:37:11 PM
Re: 2003 205 Osprey
« Reply #5 on: July 03, 2020, 12:37:11 PM »
Here's something that might give you an idea as to how it works. Sorry no pics but somewhat descriptive.
https://classicaquasport.com/smf/index.php?topic=13140.msg132144#msg132144
Good luck. :thumright:
July 13, 2020, 11:12:01 AM
Sail2power
Re: 2003 205 Osprey
« Reply #6 on: July 13, 2020, 11:12:01 AM »
Morning All,
A update to the cockpit drains. Pulled the thru hulls and found a rubber plug had been driven up inside the thru hulls. Thinking about replacing them with a Thru Hull scupper With a flapper that Attwood marine makes. The only problem I see, is that they are to be installed 12” above the water line. Any one tried these
Sail2power
