Author Topic: Deck Crown  (Read 248 times)
June 20, 2020, 10:36:02 AM
Read 248 times
umecheme
  • NorthEast
Deck Crown
« on: June 20, 2020, 10:36:02 AM »
As I'm "rebuilding" my stringers, I was trying to true up the outside stringers to the inside stringers, and then I got thinking about water on the deck.  Am I supposed to leave a crown in the deck so the water will run to the outsides and then out the back.  If so, how much crown should I leave?  Half inch from the inner to outter stringers?  Less?
Any thoughts or help is appreciated.
June 20, 2020, 10:39:09 AM
umecheme
  • NorthEast
Re: Deck Crown
« Reply #1 on: June 20, 2020, 10:39:09 AM »
I should say, from the inner stringer to where the outter stringer meets the hull.  Right now its about 1/4 inch down to the inside of the outter stringer, and a half inch where the outter stringer meeets the hull...
June 20, 2020, 12:51:40 PM
Re: Deck Crown
« Reply #2 on: June 20, 2020, 12:51:40 PM »
I would think 1/4" is plenty of crown
June 22, 2020, 08:20:51 AM
dbiscayne
Re: Deck Crown
« Reply #3 on: June 22, 2020, 08:20:51 AM »
I don't think deck drainage is hindered with or without a crown, my boat typically never sits still long enough for any crown to the deck to help drainage. Just a little bit of unbalanced weight will negate the effects of the crown.
