22-2 Rebuilds
78' 22-2 Rebuild (First time doing this)
Topic: 78' 22-2 Rebuild (First time doing this) (Read 4032 times)
June 11, 2020, 11:08:08 AM
Read 4032 times
Caldozx6rr
June 11, 2020, 11:08:08 AM »
Here is what im starting with.
Getting some first time glass work in!
A few air bubbles to fix
June 11, 2020, 11:17:45 AM
Caldozx6rr
Re: 78' 22-2 Rebuild (First time doing this)
June 11, 2020, 11:17:45 AM »
Two layers of 1708 inside the 2" lip of the old transom to build it up level with remaining layers. Three layers over that tabbed at 4", 8", and 12". Next step is to cut the coosa is there an easy way to "stencil" the current shape of the transom?
June 11, 2020, 03:22:09 PM
June 11, 2020, 03:22:09 PM »
Good progress.
Before you get to the next step you might consider adding a PVC pipe to the transom before you move the low point too far forward.
Here is a link to where I explain the thought of the PVC pipe
Here is a link to where I show what is actual problem
Also, when you take a picture with your phone try to remember to hold the phone horizontal so the lens is to the left. That will make the pic orientation marker correct for forums. I rotated the pics in your gallery.
June 11, 2020, 10:09:40 PM
Caldozx6rr
June 11, 2020, 10:09:40 PM »
Thanks Rick yeah I realized the phone thing after! I plan on putting the pvc in today or tomorrow. Thanks for the reminder
October 20, 2020, 09:55:41 AM
Caldozx6rr
October 20, 2020, 09:55:41 AM »
October 20, 2020, 09:56:55 AM
Caldozx6rr
October 20, 2020, 09:56:55 AM »
Getting there!
October 20, 2020, 12:42:40 PM
Fishhead
October 20, 2020, 12:42:40 PM »
Looks good keep progress going. How much foam did you end up using in your stringers? Hope I ordered enough. What size tank did you end up getting ? Good job
19-6 family fisherman
24 osprey pilothouse
22-2 family fisherman
October 20, 2020, 01:57:08 PM
October 20, 2020, 01:57:08 PM »
I hope you allowed 2% for the gas tank to grow once it gets gasoline in it. That's 2% in every direction. Progress looks good.
October 21, 2020, 11:16:30 AM
Caldozx6rr
October 21, 2020, 11:16:30 AM »
I forget the exact amount of foam used but it was around 800$ worth. And the tank is a 55 Gallon tank from Moeller. Thanks Rick it’s still just sitting on top of the foam. What are the consequences of not allowing the expansion space?
October 21, 2020, 06:01:12 PM
Reply #9 on:
October 21, 2020, 06:01:12 PM »
They say the tank could crack or crack the surrounding area.
November 04, 2020, 09:42:19 AM
Caldozx6rr
Reply #10 on:
November 04, 2020, 09:42:19 AM »
Anyone know if a Bobs 14inch offfset jackplate would work? Not a huge fan of the cost of a Porta-Bracket.....
November 04, 2020, 11:17:07 AM
Reply #11 on:
November 04, 2020, 11:17:07 AM »
The problem with a jack plate is they don't raise up enough for you to tilt the engine up and over a full transom.
November 04, 2020, 01:21:38 PM
Reply #12 on:
November 04, 2020, 01:21:38 PM »
I looked at that option when I did mine but ended up finding a used porta bracket instead. I was able to clean it up, replace a few things and wire it up for less than the cost of the 14" jackplate. Bob's also makes additional spacers if you need a little more clearance but that additional cost just made the porta a better choice for me.
November 11, 2020, 08:45:42 PM
Caldozx6rr
Reply #13 on:
November 11, 2020, 08:45:42 PM »
Thanks Mike I think I’m going with a porta bracket.
March 11, 2021, 09:10:02 PM
Caldozx6rr
Reply #14 on:
March 11, 2021, 09:10:02 PM »
22-2 Rebuilds
