Author Topic: 1996 Osprey 225 Motor Upgrade..... shaft length question  (Read 315 times)
June 07, 2020, 02:30:09 PM
Read 315 times
Rocket1010
« on: June 07, 2020, 02:30:09 PM »
Been a member since picking up a 225 Osprey last year, lots of great information here for sure. Thanks!
My 225 Johnson has seen its better days and I am looking to upgrade to a newer outboard. I have found several aggressively priced 30" shaft length motors. Will this cause issues or should I stay the course and install another 25" unit?
June 07, 2020, 05:53:08 PM
Re: 1996 Osprey 225 Motor Upgrade..... shaft length question
« Reply #1 on: June 07, 2020, 05:53:08 PM »
Well the hull was designed for a 25". The 30" will need to be mounted higher (jack plate ??) or you will lose performance. I'd keep shopping for a 25".
Good luck. :thumright:
June 26, 2020, 03:15:27 PM
« Reply #2 on: June 26, 2020, 03:15:27 PM »
If you get a super deal on a 30, it's not a big deal to convert a 30 to a 25 - much harder to go the other way.  For some models, all you need a 25 driveshaft, shift rod, and water tube.  Take the 5" spacer out from the mid, change the shaft, shift rod, and water tube, and put it back together.  Now you've got a 25.  Sometimes you can cut the water tube and not have to replace it.  And lots of shops have driveshafts laying around...
Good luck!
