Author Topic: A lot of water in my 225 hull  (Read 286 times)
May 28, 2020, 10:02:20 AM
Read 286 times
adnan.begic1
« on: May 28, 2020, 10:02:20 AM »
Anyone else leave the ramp with gallons of water in their bilge? I dont know what it could be.. some trips shes dry as dirt and others we could fill up a bucket. Any info helps thanks guys
May 28, 2020, 12:37:41 PM
Re: A lot of water in my 225 hull
« Reply #1 on: May 28, 2020, 12:37:41 PM »
Live well maybe? Could explain why sometimes it is dry?
May 28, 2020, 12:38:44 PM
« Reply #2 on: May 28, 2020, 12:38:44 PM »
OK,
Let's ask a few questions.
Is your boat trailered?
If so, is it covered really well or exposed to the elements?
Prior to going out on the days that you returned with water in the bilge, had it rained earlier in the week?
On the days you returned dry, had it been dry prior to going out?
EXs are notorious for collecting water in the forward bilge unless raised very high (in front) while trailered.
During the day, depending on the seas, you can take water via the bow rail mounts and the rub rail. This happens in the areas that are not properly sealed.
I'm guessing' from your "sometimes wet, sometimes dry" post it might be the former.
