Author Topic: Fuel problem on my 215 DC  (Read 224 times)
May 20, 2020, 10:24:10 PM
Read 224 times
Flakristine15
« on: May 20, 2020, 10:24:10 PM »
Hello. I am new to this site so thank you in advance for any input.  Looking for suggestions for difficulty with getting fuel. I changed the fuel line to the engine from the fuel water separator and primer bulb and am still unable to get gas when I try to prime. Have new fuel line on order to replace line from tank to fuel water separator. Any other thoughts?thanks
May 20, 2020, 10:31:43 PM
Re: Fuel problem on my 215 DC
« Reply #1 on: May 20, 2020, 10:31:43 PM »
So you did change the primer bulb, correct?
May 21, 2020, 10:19:38 PM
boatnamesue
  • Jason
« Reply #2 on: May 21, 2020, 10:19:38 PM »
Give a little more detail if you could....are you squeezing primer and no fuel is being pulled into bulb....or you cannot squeeze because bulb is full/hard?
If the former, then either the bulb is bad, the tank isn’t venting, or fuel line between tank and bulb has hole.
If the latter, then either the bulb is bad or an obstruction is upstream.
Jason
1976 AS 170
1998 S115TLRW
