Author Topic: 1981 200XF - Leaky Windows  (Read 566 times)
May 12, 2020, 08:24:46 AM
Read 566 times
inletcomputerworks
« on: May 12, 2020, 08:24:46 AM »
I'm currently bringing back to life a 1981 200XF, among the myriad of projects ongoing with her I've noticed the rubber gasket that seals in the windows has shrunk and become dry and brittle from UV exposure.
I would like to replace this gasket material with something new yet I have no idea where I could source the material from. Have any you guys dealt with this issue?
May 12, 2020, 08:48:09 AM
Re: 1981 200XF - Leaky Windows
« Reply #1 on: May 12, 2020, 08:48:09 AM »
Yeah this is going to be tough. I doubt you'll find originals but may find gaskets that will work online somewhere.
May 18, 2020, 09:27:07 AM
captaincahill8
« Reply #2 on: May 18, 2020, 09:27:07 AM »
It may not be the absolutely correct way, but could you use some clear silicone seal? lay in a bead screw the windows back in and let is spooge out. and whip away the extra?
May 18, 2020, 07:13:50 PM
inletcomputerworks
« Reply #3 on: May 18, 2020, 07:13:50 PM »
That's exactly what I ended up doing, only I used black silicone because it matched. I then used black rustoleum around the entire windscreen. I plan to try 'rubber renew' we'll see if that does anything. I don't have high hopes, but it's worth a try.
May 18, 2020, 08:13:49 PM
« Reply #4 on: May 18, 2020, 08:13:49 PM »
Yup, have to be creative.
May 26, 2020, 09:53:56 AM
captaincahill8
« Reply #5 on: May 26, 2020, 09:53:56 AM »
I just had to do the same on my 246xf windows. It worked out and they stayed dry through the rain in CT this weekend.
