Author Topic: Lookinng for front anchor door 1974 170  (Read 526 times)
May 03, 2020, 11:02:36 AM
Read 526 times
64conv65hard
« on: May 03, 2020, 11:02:36 AM »
Looks like a squirrel decided to make a home in the front storage compartment where the anchor sits. The hole to access the lock to open wasn't adequate for him so he chewed a more fitting hole for easier access. I've been looking for a teak replacement board and just make one but the search for 3/16 teak plywood isn't working. If anyone has a door or can point me in the right direction I would greatly appreciate it...……...Kevin
May 03, 2020, 11:31:03 AM
Re: Lookinng for front anchor door 1974 170
« Reply #1 on: May 03, 2020, 11:31:03 AM »
While it sounds like you want to DIY the hatch cover, you may wish to give this member a call.
http://louveredproductsunlimited.com/
Good luck. :thumright:
May 03, 2020, 07:03:50 PM
wingnut
« Reply #2 on: May 03, 2020, 07:03:50 PM »
Can you post a photo? I JUST took the front hatch off my 1986 170 and replaced with a watertight hatch. I was going to post and see if anyone could use mine. If it fits you can have it, just cover shipping.
May 03, 2020, 09:34:50 PM
boatnamesue
  • Jason
« Reply #3 on: May 03, 2020, 09:34:50 PM »
When I bought my ‘76 170 it did not have a bow locker hatch.  Finally got around to installing one just a few weeks ago.  The dimensions of the access hole are unique, so unless you intend to fabricate yourself, you’ll need to widen the access to accommodate the hatches available on the market.  My access was 16” wide, which caused me havoc when removing and stowing my anchor.  So I choose to significantly widen so I could install the hatch pictured below.
Jason
1976 AS 170
1998 S115TLRW
May 04, 2020, 01:23:24 PM
« Reply #4 on: May 04, 2020, 01:23:24 PM »
You could also look locally for Brazilian Mahogany and buy 18" of it (x width needed top to bottom) x 1" thick to make your own.  I agree that pics would help us.
June 04, 2020, 07:22:52 PM
64conv65hard
Re: Looking for front anchor door 1974 170
« Reply #5 on: June 04, 2020, 07:22:52 PM »
sorry for the delay, my boat is not local and was just able to get a picture of the door
June 05, 2020, 06:35:06 AM
« Reply #6 on: June 05, 2020, 06:35:06 AM »
I would go the Brazilian Mahogany route - mine are still looking good.
June 07, 2020, 07:32:37 AM
Mwar410
« Reply #7 on: June 07, 2020, 07:32:37 AM »
Here’s  one I laid up rather simply
I didn’t have anything to go from so I just winged it. It’s not a tight overlapping /inset fit, but does seem to stop some of the water. Made it from teak scraps, didn’t want to deal with plywood delamination.
1978 "170" 91' Yamaha 90hp
Mike
